what should i do next
I have a 1994 camaro z28 With k&n cold air intake, pacesetter long tube, no cats, 4.10 gears, and a pcm for less tune...just trying to see what can i put on there next that thats only $300 to $400....to increase throttle response.
do you have a cat-back system or a cutout? ... after that its about time to cam it or put some suspention on it
could also put springs and 1.6 roller rockers on it
i dont want to dyno tune yet because i still want to do head and cam, summitracinga sale roller rockers should i buy from there
Posted from LS1Tech.com App for Android
@mystery bird i have a 4l60e not a 6 speed. my friend has a ls1 with 4.11 gears and a hypertech pp3 tune and drives on the freeway find
Originally Posted by Sumbalt1
@mystery bird i have a 4l60e not a 6 speed. my friend has a ls1 with 4.11 gears and a hypertech pp3 tune and drives on the freeway fine
4.10 gears with an auto, alright maybe it's time to look into getting a quality converter. Altough 4.10's should already be getting that thing moving pretty quick though huh?
Aftermarket throttle bottle, bigger MAF sensor ends..I personally wouldn't do either as they say the stock TB and MAF is perfectly fine. I would look more into suspension to hang with LS1's, if your putting the power to the ground you can beat them. Check the below list.
1) UMI 2 point weld in SFC
2) UMI 2 point strut tower brace
3) UMI lower control arms
4) UMI Pan hard bar
5) UMI bolt in relocation brackets (then weld in)
6) LS1 driveshaft
7) Underdrive pulley
4) UMI Pan hard bar
6) LS1 driveshaft
Your going to need pic either a cam, converter, or nitrous to keep up with LS1 cars with a 50hp advantage....either that or FULL bolt ons: cat-back/true dual exhaust, electric WP, 52mm TB, 1.6 RR & springs, with some suspension stuff like control arms, LCA relocation brackets, tires, ect. I would start with all the bolt on stuff or stall as it's needed once you change out the cam/heads ect. down the road.
