Anybody runnin Billet Specialties on f-body with C5 brake conversion?
I am wanting to get a set of billet Specialties wheels but am having issues with the C5 brake conversion on the front of my 00' Z28. The two styles I like are the Street Smart Launch and the Street Lite. I want to run 17x9.5 front and 17x11 rear. Issues I am potentially seeing are the distance from the hub mounting surface to the front side of the caliper (hitting back side of wheel spokes) and then caliper hitting the barrel of the wheel due to now having 13" rotors and distance of center hub to outer edge of caliper being bigger than stock.
Anybody running either of these wheels? The protouring or SLC are supposed to fit, but they are too pricey and I like the other styles better. I am going to try and get an accurate measurement from my car, but would be much happier knowing if anybody is currently running these.
thanks
thanks
Customizing Director
Running the same size setup as you mention. Its a really tight fit with just the factory setup. I was looking into a 13" rotor setup as well but put it off since I have other things to work on first.
If you are running the corvette calipers as well, the "corvette" lettering that is risen from the caliper won't fit the street lites.
thanks for the info. Yes, I am running the vette rotors and red Z06 calipers. It looks like the street smart line has 1" of clearance between the back of the wheel and mounting surface. Street lite only has 5/8". How much clearance do you have between the inner barrel and the outside of the caliper? I actually had to grind off the fins on my calipers about 6 years ago because the two sets of road racing wheels I had didn't fit!!! They work well, but the C5 set up has been a PITA for lots of other things.......
I measured the best I could the other day and It appears that I have closer to 7.75" from the center of the hub to the outter edge of the caliper...... It dosen't appear that the caliper will clear the barrel. I do however have enough room to clear the back of the spokes on the street smart. A ride down to BS may be in order since they are relatively close to me.
Shoot me a PM if you want some details.
Man..... I was hoping that somebody would have a yes or no on fitment of these...... I saw a black Z28 roll by with the street lites and they looked really good. Had stock brakes though. Looked on vette forum... nothing. Called Speed Inc.... they never tried. Called Billet Specialties.... they don't know. Called a couple distributors.... they don't know either. I would think with all the C5 conversion kits out there and people who have done it, that somebody would have figured it out??? Guess I will have to maybe the be the guinnea pig and go check. Still have to pull wheel again and try to get a more accurte measurement of the hub center to caliper outter edge diameter......
