93 TA What To Do About A Tune
Old 08-01-2012, 01:20 PM
StraightTimeStirrups's Avatar
Default 93 TA What To Do About A Tune
Here is the specs on the Engine side of the car:
1) Long Tube Headers 2 1/2" Collector to Single 3" Split Core Dynatech Muffler Dump IFoA.
2) EGR Delete
3) Air Pump Delete
4) Cat Delete
5) Will Install new O2 Sensor this week
6) Snorkel Delete
7) Will probably do all of the normal Freebie and Easy Bolt-On mods soon.
Who should I get to do a tune for me and what can I expect to pay for such a service? Do I have to send anything into them etc? As far as I know, my car is on the stock tune.
Joe
Old 08-01-2012, 01:34 PM
Adam1203's Avatar
Madz28.com or PCMforless does tunes to I believe there is a few sponsors that do mail order tunes. I here Moe is a really good stand up tuner but I am not sure about his contact information or if he does mail order tuning.
Old 08-01-2012, 01:56 PM
93M6Formula's Avatar
I have similar mods on my '93 and went with a PCMforless tune. Works great for me.
Old 08-01-2012, 05:19 PM
What does a tune from them cost and what is involved in the process?
Joe
Old 08-01-2012, 05:23 PM
FormulaTA96's Avatar
http://www.pcmforless.com/
You just fill out a ordersheet online with some general info on your setup and then you send your PCM in to them.They charge 190.00 (175.00 + 15.00 shipping).
Old 08-01-2012, 05:47 PM
turtle93's Avatar
I use Pcmforless 13.5 at 103 before and 13.0 at 108 after plus I got my mpg back
Old 08-01-2012, 06:21 PM
What is their turn around time?
Old 08-01-2012, 06:23 PM
For a 1993 and earlier, they are asking for a Broadcast Code? What is that?
Joe
Old 08-01-2012, 06:33 PM
FAD2BLK93's Avatar
It is the three letter code printed on the memcal piece that is under the lid inside the computer. I believe it is printed on the outside of the box ( ie bnx, brl ect). As far as 93, its a little diferent. U dont send in computer. U fill out ordersheet pay 150 and they send u a curciut board that your chip plugs into. My turn around time is 5-7 days. The great thing about it is if u make changes it only cost 50 to reflash. I gained .2 or twenty horse on the first flash with boltons. Pcmforless has always been good to me. Oh if u can datalog and send them the file they can really dial it in for u. Good luck.
Old 08-01-2012, 07:14 PM
Where is the chip at on a 93?
Secondly, if you have the mods done that I have listed and don't have a tune for them how does the engine react? I've never driven my car as I got it with the M6 taken out (I removed it for the cars owner and he gave me the rest of the car) so I have no experience with this car. I do have the car running but the exhaust has not been finish welded yet so I can't drive it yet to get a feel for the car but it seems to be running rich with a slight miss, but it's hard to tell if it's actually a miss without a load on the engine!
Old 08-01-2012, 08:53 PM
defaultexistence's Avatar
You will need to do the heated o2 conversion and ONLY run delco afs75's .. This point is tried and true .. You don't send the ECM to anybody.. There is a removable door/plate on the ECM where the chip is snapped onto the main ECM board .. You need an adaptor from moates to plug the new chip into ... I have a good bolt on 93 tune for you if you want.. It's been fine tuned so it should be damn close to what u need... Pm me you like, I'm quite in tune with my 93 383 lt1.
Mike
Old 08-01-2012, 09:17 PM
Do you know of a write up for the heated o2 Conversion?
Old 08-01-2012, 09:21 PM
Yep...
https://ls1tech.com/forums/lt1-lt4-m...t-headers.html
Some links no longer work.. But i will get going the right direction..
Old 08-01-2012, 09:27 PM
Basically you just wire in 12v to the correct wire.. I tapped the fuse/relay box for 12v when IGN key is switched on.. Google or search here for diagrams .. It's easy and makes for better idle ,tuning and milage ... I went back to delco afs75's be sure to use only them.. All other brands rich/lean thresholds are off and cause issues..
Old 08-01-2012, 09:32 PM
Here's the sensor afs75 pn#19178930
http://www.gmpartsdirect.com/
Old 08-01-2012, 09:35 PM
Read up http://www.fastbirdperf.com/93-97F-B...Directions.doc
Old 08-01-2012, 09:37 PM
Do you run one or two with this conversion? I'm assuming one.
Joe
Thanks for all of your help everyone!
Old 08-01-2012, 09:47 PM
2..……… one on each header .......
Old 08-01-2012, 09:55 PM
I guess the speeddenSity.org site is no longer any good. Where can you buy the wiring kit or should I just make my own harness?
Joe
Old 08-01-2012, 10:05 PM
Easy enough to just make one , just be sure to solder the ECM wire to o2 splice you make aft of the OEM weather pack connection.. Crush tubes just won't do
