Should I get 241s or 243s?
I know 243s have better flow but cant find any to cheap. 241s are every where and i know i can get them really cheap. Would it be better and cheaper to get some 241s or keep trying to find 243s?
when i did my build i did 243's,Raptr Cam,ls6 intake,LT's,42lb injectors ,racetronix pump. M6 car made 423/385 on a mustang dyno.
the 243's i bought off ebay for $450. they had a few knicks that needed scuffed down but other than that they are fine. not ported or anything.
What he said.
If you just want cores to send in for porting, you can save money by getting the 853 instead of the 241s. Once ported there will be no difference.
Also, instead of looking for 243, look for some 799 they are often cheaper and are the same design as the 243.
If you do not plan on porting the heads, replacing any other stock head with a 241 is a waste of time.
