Sponsored by: DashLynx
Finally did it, repaired the faded tail light.
Old 08-08-2012, 10:09 PM
Sail Hatan's Avatar
Default Finally did it, repaired the faded tail light.
Followed a few write ups on here and decided while my computer is out, I'd relocate my traction control, and more importantly, fixing the corroded tail light.
So I pulled it off, and stuck it it the oven at 220. Mistake one. Putting it directly on the rack will warp it. Not bad, but anyone trying should use a towel or something. So after 15-20 minutes, I popped it out and started separating. Used a knife and a flat head. It makes some horrible noises, but it's glue breaking. Finally got it apart, and it was all black. No chrome left. So I took it outside, sprayed it, and remembered to take pictures.
Here it is painted.
Then we started clamping and using rtv to seal
It up.
Here it is drying.
And here's a before.
And after!
I know there's write ups, just figured I'd share. I encourage others to try, cheap and didn't take long at all. Maybe an hour.
The following users liked this post:
ws6outlaw (07-10-2023)
Old 08-08-2012, 10:14 PM
Ellsworth's Avatar
looks so much better!
Old 08-08-2012, 10:34 PM
porksoda's Avatar
What paint did you use?
Old 08-08-2012, 10:35 PM
transam5.7lt1's Avatar
I did that to mine but mine had already some damage from a "previuos fix" and it eventually cracked at the corners a little. It served me well for about a year until I bought a new taillight. Yours came out perfect! Congrats on the fix!
Old 08-09-2012, 01:25 AM
crimson_bird's Avatar
damn, I need to do this asap!!! that came out great
Old 08-09-2012, 03:26 AM
BadBirdie's Avatar
i did this as well a couple months ago. it came out near perfect however i could still tell the other tail light was still a tad bit brighter and i could see through the reverse lights that it was more reflective than the chrome spray paint i used. i've been wondering if using reflective chrome tape would have been a better choice. even tho its not perfect, its a huge improvement from what i had to start with and no one notices unless i tell them to specifically look which light is brighter.
Old 08-09-2012, 05:25 AM
Sail Hatan's Avatar
Thanks for the kind words, I used black rtv, and dupli color
Chrome paint. The 99¢ clamps from harbor freight worked perfect.
Old 08-09-2012, 05:34 AM
Sail Hatan's Avatar
I may take apart the other and paint it so the reverse lights match a little more, but my reverse light used to be black, so it looks better now.
Old 08-09-2012, 01:25 PM
Sawzall and Welder Mod
Whistler's Avatar
You could always do the other one in the same paint so they match....
Old 08-09-2012, 02:05 PM
Sail Hatan's Avatar
Yea I might, but for now they match. So I'm
Happy.
Old 08-09-2012, 10:55 PM
BadBirdie's Avatar
its not that big of a deal for me, mine are close enough that its not worth the hassle to try and seperate the other one. and like sail hatan said, the faded one used to be black so at least its back to reflective chrome.
Old 08-10-2012, 05:33 AM
Sail Hatan's Avatar
Exactly, maybe of the cars down sometime for a day or two ill do the other. But for now it's so much better to look at.
Old 12-22-2012, 09:40 AM
LOHRTBT's Avatar
Oh so that is why most of the F-bodies have one darker looking tail than the other. NICE!
Old 12-24-2012, 05:36 AM
Sail Hatan's Avatar
the best stuff to use is probably VHT chrome plate spray paint, but i didnt have that readily available. lol.
Old 12-24-2012, 10:07 AM
nascarnate326's Avatar
crazy that they dont make new tails for these cars yet. Come on year one/ 6LE, theres good money waiting to be made.
Old 12-24-2012, 11:30 AM
DaRReLL's Avatar
nice fix...
Old 12-24-2012, 01:29 PM
ramairetransam's Avatar
i could see year one remaking these , 650 bucks for a set if not more. It will be 30 more years before someone makes them if they even do .
Old 12-24-2012, 02:51 PM
CamaroSS27's Avatar
looks 10 times better good job!
Old 12-24-2012, 03:37 PM
Sail Hatan's Avatar
Thanks! I've been thinking about tackling the other side, so they're even.
Old 12-25-2012, 08:55 AM
9WhiteCamaro9's Avatar
Those look a lot better OP. Great work.
Quick Reply: Finally did it, repaired the faded tail light.
