Notices
need axel shaft for 1995 pontiac trans am
Old 08-11-2012, 04:16 PM
bobbyk3lly's Avatar
Default need axel shaft for 1995 pontiac trans am
like it says, need an axel shaft, i bent mine playing alittle to hard,
my passenger one is bent so thats what i need, not sure if drum brake cars shafts will work.
looking for something in good shape, may buy a pair, or i have ws6 parts to trade for some
Old 08-11-2012, 07:24 PM
Ocala93TA's Avatar
I have two off a 95 TA in perfect condtion Pm if your interested
Old 08-12-2012, 10:45 AM
charchri4's Avatar
I've got 2, 3 channel shafts from a 99 z28 in perfect condition. Do you need 3 channel or 4?
Old 08-12-2012, 12:32 PM
bobbyk3lly's Avatar
anything newer then 97 will not work, theyre an 1/8th of an inch shorter then lt1s
Old 08-12-2012, 12:33 PM
bobbyk3lly's Avatar
how do you tell if i have a 3 channel or 4 channel?
Old 08-12-2012, 08:50 PM
charchri4's Avatar
4 channel is for a car with traction control and it has a reluctor ring on each axle for each wheel sensor. 3 channel only has 1 reluctor on the ring gear in the carrier and nothing on the axles.
Old 08-17-2012, 06:51 PM
bobbyk3lly's Avatar
mine sometimes says low trac when i get on it. would that mean i havea 4 channel? or do i have to have the TCS button?
Old 08-20-2012, 08:06 AM
charchri4's Avatar
Not sure because I have never had a non traction car. Just look under your car and see what you have. If there is a wire going to the backing plate on both wheels then you have a 4 channel. If there is only 1 wire going to the top of the axle in the center and no wires to the wheels then you have a 3 channel.
Old 09-10-2012, 06:38 PM
bobbyk3lly's Avatar
axle shaft no longer needed, thanks guys
Quick Reply: need axel shaft for 1995 pontiac trans am
