Fueling & Injection - Gas Gauge Issue
View Full Version : Gas Gauge Issue
PistonLessRX
08-14-2012, 08:13 PM
I have a 98 Z28, I bought it about 2 weeks ago and the gauge has not worked since. I pulled the sending unit and checked the ohms and it reads correctly as I move the float. The gauge stays at Full, when I turn the ign off it sometimes goes to 3/4. I pulled the cluster, set it at E and turned the key on and it went right back to Full. I have searched and all I have seen are instances where the sending unit are bad. Im not sure what else to check. Any ideas?
rbertjr
08-16-2012, 08:28 PM
I have a 98 Ws6 doing the same thing.
PistonLessRX
08-16-2012, 08:41 PM
I wired up a auto meter fuel level gauge today and it went straight to full.. so im thinking my sending unit is bad and its not reading the ohms right and i thought it was..
rbertjr
08-16-2012, 08:47 PM
Somebody else told me that it was probably the fuel sending unit...I changed it last year (AC Delco) and I'm really not looking forward to changing it again. Are you planning to change yours soon? If so, could you please let me know if it fixed your problem? Thanks.
PistonLessRX
08-17-2012, 09:38 PM
Im planning on changing mine as soon as i find a replacement for a 98.. I will let you know if it fixes my problem though.
caturnbull1
08-17-2012, 09:42 PM
idk if you did it already or not but fill it up start the car then put the needle on full.
caturnbull1
08-17-2012, 09:44 PM
and when you said you set it on E you did take it off and put it on E? also if you had ignition off when you did it im not sure but i dont think it sits right at E.
PistonLessRX
08-18-2012, 07:48 PM
I have not replaced it yet, but i had the needle set on the E mark then turned the ign on and it went straight back to full. I know its the sending unit now though after I wired up a aftermarket gas gauge..
rbertjr
12-26-2012, 12:41 PM
Okay, I finally was able to obtain another fuel sending unit. I replaced it and the fuel gauge now works fine.
