s10 rear mount turbo kit
hello, i was wondering if anyone would be interested in buying the whole entire rear mount turbo kit to my s10. im thinking on doing twins up front but i would need to sell this in order to do so. it would include headers, hotside pipe, wastegate, turbo + extra turbine housing, coldside pipe, intercooler, blow off valve, oil pump, oil lines, and all couplers. i would be willing to part it out, but if it were parted out, i would keep the blow off valve. here are some pics
cold side pipe
hot side pipe
oil pump location (old intercooler pipe)
oil drain return
http://youtu.be/plMHFwDg2wM
http://youtu.be/4naEUgfM7Vc
the oil feed is on top of the oil filter on the engine block. the oil return can be routed to the oil fill cover but you might need to buy more 1/2" fuel hose but thats no big deal. you would also need to cut the holes in the bed obviously and make mounts for the intercooler underneath. i will add in another v band for ease of installation and shipping. i will sell everything for $1700 shipped. i dont need to sell this set up but i think it would be cool to do twins. i would like to sell as a hole. i wont part it out until winter comes.
cold side pipe
hot side pipe
oil drain return
