At what point (PSI) do i need head studs??
putting a supercharger on soon and wanted to know if I need to be installing studs or if arp bolts would be good enough? I probably only going to run around 6-8psi boost, its a Centrifugal-type supercharger on a cammed LS2
Timing plays a huge role in your cylinder pressures.
15psi @ 10* = no studs
15psi @ 20* = lifting heads on TTY's
This is just an example - everybody's combo will be completely different.
