At what point (PSI) do i need head studs??
Old Aug 23, 2012 | 02:36 PM
3rdCoastPowerSports's Avatar
Default At what point (PSI) do i need head studs??
putting a supercharger on soon and wanted to know if I need to be installing studs or if arp bolts would be good enough? I probably only going to run around 6-8psi boost, its a Centrifugal-type supercharger on a cammed LS2
Old Aug 23, 2012 | 02:39 PM
9sectruck's Avatar
I would say when you get to the double digits on boost, a buddys vett seen 12psi with no problem but that would be far as I would push it
Old Aug 23, 2012 | 03:06 PM
tunedportcj5's Avatar
Timing plays a huge role in your cylinder pressures.
15psi @ 10* = no studs
15psi @ 20* = lifting heads on TTY's
This is just an example - everybody's combo will be completely different.
Ferocity02's Avatar
With 6-8psi you would likely be fine on stock head bolts.
Old Aug 23, 2012 | 11:26 PM
stangtrader's Avatar
Ike everyone saying depends on the combo. I ran #16 on a stock lq4 long block including tty bolts on 13° no problems.its all in the tune
Old Aug 23, 2012 | 11:59 PM
I8UR4RD's Avatar
id focus more on the tune and compression.
Old Aug 24, 2012 | 03:26 AM
Outlaw666's Avatar
curious...
what about ARP bolts?
would the same numbers apply to them, even being a stronger than factory bolt?
Old Aug 24, 2012 | 04:08 AM
stock48's Avatar
9 Second Truck Club
^^^^This.
