Check engine !!! Help
Good morning,
i was driving under normal condition. around 40km/h or so
anyway, the Check engine light came up but everything was running perfect
am having a problem with knocking though its not that big.
i tried down shifting, high rpm, flooring it or abnormal but didn't notice a thing
i even check the fuel cap if its tight and it is.
its a 1998 camaro Z28 i have 127000 KM done
LS1
any ideas ??
thnx
LS1
any ideas ??
thnx
if i have low oil will it trigger check engine ?
or it is set only to trigger when there is a problem with emission system.
because i removed the catalytic converters before but already took it to a programmer to do his thing with the o2 sensor
Save the manuals!
You probably still have the codes stored in the car's computer. You should get that scanned to see what the problem was. (The condition may have temporarily gone away - but the odds are that it will come back.)
You should be able to buy an inexpensive scanner, which will pull the codes for you from the car's PCM. Form there, you can find out where the problem was by looking up the code.
@wssix99 i dont have that light in my camaro but i di have low oil pressure light and my camaro dont have the service reminder light and even doesnt have the oil/trip holding method to reset it ... i hope that it doesnt come back and i'll take it to my programmer to see what triggered it
its been like that since the day i bought it, or even the pre-owner did
when the oil is warmed up it give me 20-25 PSI idling
consider that i live in Bahrain
Weather temperature is around 40-48C
