Sway Bar
Sway Bar
Im looking to buy sway bars but theres hollow then solids then different diameters so what set up is the best hollow, solid, diameter size?
35mm/22mm are a common handling set for these cars.
Solid vs hollow is personal preference weight-wise. I can't speak for every manufacturer but the popular sets of hollows with diameters similar to 35/22 tend to be slightly lower in rate while still maintaining the same balance. Most of the sway bar action happens on the metal around the outside diameter (the middle is just along for the ride).
Tell us more about how you plan to use your car.
ramey
Of course it depends on what your handling goals are.
ramey
ramey
I said more handling since its my daily driver but sometimes i do drive alot like a man with road rage when im running late to wrk or act like a idiot when i get others wanted to race
You want a good guideline to start from? Go with the strano swaybar set. If you want to save a little money, go with a 32mm front bar and stick with the stock rear.
Hollow saves you weight while being nearly as stiff as a solid bar of the same size.
Its not the hollow vs solid for traction, its the bar thickness. Generally a 25mm (hollow or solid) rear bar is a drag bar, something you dont want for handling, especially if you have a stock front bar.
It seems the strano sway bars are pretty popular here so whars a good vendor to buy it from o tried major vendors like summit racing dont carry it
stranoparts.com
Thanks i appreciate i guess it does not really matter of its hollow or solid i just have to make sure its 22mm or lower and 35mm in the front since i really dont drag its mainly for daily driver and some street racing here and there
Solid vs Hollow... The only difference is stiffness and weight. A solid bar is stiffer than a hollow bar of same exact size and material. However, most hollow bars aren't that much less stiff. In general hollow bars provide a better tradeoff on weight vs stiffness.
