cam gurus, opinions needed please 404ci single 88 build
OK guys need some help choosing a cam, car is going to be mainly street driven but will see a fair amount of track as well. Here's the engine specs
404ci
4.010 bore
4.00 stroke
10:1 to 10.5:1 compression depending on how much I mill the heads
As cast LSA heads later will probably get them cnced
Head lift will be the limiting factor As far as boost but I'd like to see 18lbs
Studded througout
E85
Turbo will be either a forced inductions hp88 or just a s480 96/1.32
Th400 or 4l80
Car should weigh in at around 3100lbs
So let me know some ballpark numbers on what you think would be good, thanks Nick
404ci
4.010 bore
4.00 stroke
Studded througout
E85
Th400 or 4l80
you know that head lift is a factor keeping you to 18psi !!!! but you want to mill the heads for your compression ratio !!!! thats the last thing you want to do !!! making the head lift problem worse!!!! anyway cant help you with cam but i am running a similar 408 lq9 ls7 style heads etc with s400 hp-88 waiting on results soon with this new turbo/head manifold combo !!!! compared to s475 stock 241s etc !!! cheers
I'm curious to see how well these heads handle higher boost. I want the compression higher for better response out of boost. I'd like to see 900rw and don't think it should be a problem getting there before lifting the heads
I would do something like either of these two:
234/234 .612/.612 114+4
or
236/236 .612/.612 114+5
I can have either of those ground for you and to your doorstep in a 5-7 business days. We also have a kit that comes with springs and push rods and many other options: http://www.tickperformance.com/tick-...r-ls6-engines/
Just substitute the Polluter V.1 for your custom grind.
or
I like the choice. A lot of guys are scared of a single-plane and an elbow because they've heard about distribution problems with airflow.
Unless you are really leaning on the tune-up or you're just being plain stupid with the tune you're not going to blow anything up.
Keep a little extra fuel in it and/or run a step range colder plug in those back holes and you'll be fine. That manifold will make more power than just about any other off the shelf manifold you could put on it, and with a turbo, mid-range power is ridiculous anyways and you won't even miss the 5-10hp you might lose at 2500rpm before the turbo starts to come on-line. With you're cubic inches, the turbo you are looking at and this cam you'll never know what lag is.
