need help, 1.9 60ft. with over 540 hp/tq
Old 09-01-2012, 06:06 PM
clebmotors's Avatar
Default need help, 1.9 60ft. with over 540 hp/tq
what exactly do I need here? I have g2 lower control arms non adjustable, umi frame mounted torque arm adjustable, double diamond subframe connectors, stock springs and shocks, (probably a big part in it) moser 12 bolt 3.73 gears, 28 10 m/t et streets on 15 prostars, i have lowering springs on stock struts up front, car is pretty much just a drag car but i do drive it on the street. Still has a/c full interior i just need someone to tell me exactly what i need to get for the track. it just is NOT hooking!
Old 09-01-2012, 07:11 PM
MUSTANGBRKR02's Avatar
What psi on the tires?
A4 or M6?
Old 09-01-2012, 07:16 PM
clebmotors's Avatar
A4 or M6?
m6 7 psi
Old 09-01-2012, 08:19 PM
duh
duh's Avatar
Shocks and springs are you big killer IMO. Maybe look at a set of qa1 or afco shocks. The adjustable ones definitely. Then it's just a matter of getting the shock settings right. That's my $.02
Old 09-01-2012, 08:43 PM
25thhawk's Avatar
7psi is way too low. I run my et drags at 15 psi. Adjustable shocks are definitely a good idea also.
Ryan
Old 09-01-2012, 08:49 PM
clebmotors's Avatar
Ryan
I raised it 10psi and was worse. What shock spring should I look into?
Old 09-01-2012, 09:00 PM
dannyz's Avatar
Your ET Streets...are they radials?
Old 09-01-2012, 09:08 PM
OIF1VET's Avatar
Good question. M6's usually prefer bias.... Adjustable shocks will also help.
Old 09-01-2012, 11:12 PM
clebmotors's Avatar
radial
Old 09-02-2012, 06:29 AM
If it's a drag car then why not lean towards a A3?
Not winning anything with 1.9 60's
Old 09-02-2012, 06:51 AM
OIF1VET's Avatar
I run QA1 12 way adjustables out back.. I don't know my spring rate though, sorry..
Old 09-02-2012, 09:51 AM
clebmotors's Avatar
Personal preference. I don't believe just sitting in a car and smashing the gas is real racing. It's how I bought the car and how ill keep it. So, stock springs with adjustable shocks or what?
Old 09-02-2012, 09:55 AM
25thhawk's Avatar
Radials are never gonna take that kinda power without a slipper clutch. Get some bias ply's. Qa1's are a decent shock. I have a used set if ur interested. I didnt like the ride quality so I switched to Koni DA's. Stock springs really arent that bad. Right now the tires are your biggest problem.
Ryan
Old 09-02-2012, 10:08 AM
clebmotors's Avatar
Ryan
I might be interested. What was it about the shocks you didn't like? Did they do what they were supposed to do at the track? Do you have front and back? Thanks.
Old 09-02-2012, 10:26 AM
duh
duh's Avatar
Go with stock springs in the rear with a QA1 12 way adjustable shock. Set it right in the middle for your first pass. QA1 front shock with a 275-300 in/lb spring. Take the front sway bar off. Set the front shocks loose (1 or 2 clicks from the loosest setting). From there set the radials to about 10 psi. Launching at 4500 will pull the front end off the ground about 3-4" assuming there's good track prep. Last car I set up like that ran an 11.5 and he was cam only. He also had steel shift forks, a centerforce clutch and a 12 bolt out back, but he was still full weight
Old 09-02-2012, 10:31 AM
clebmotors's Avatar
Awesome info! So maybe a front spring off a 6cyl.?
Old 09-02-2012, 10:33 AM
Mean87SS's Avatar
We need to know more about the combo.
What are you launching at? Are you spinning? Are you getting wheel hop?
Old 09-02-2012, 10:35 AM
Mean87SS's Avatar
No, go look at QA1's they have theyre own springs with different rebound weights.
Old 09-02-2012, 10:37 AM
1lejohn's Avatar
You need to be able to adjust the lower control arms. You need rear control arm re location brackets. You need an adjustable pan- hard bar. Then you will need to do some work.
The rear needs to be centered left - right. You need the rear centered fore to aft.
Then find the I/C of the car adjust you T- arm and control arms from there.
Its hard for me to write all this out do a search. Here goes any way you want the rear control arms to point up at there front mounting point. They need to intersect the T- arm. You can do this with string. Drop a piece from the front t arm mounting point then run another piece from the frt rear control arm point. The two pieces should intersect with the string from the rear going up towards the frt of the car . The higher the better.
This is a good start.
Most door cars use the shifter mounting point as the center of gravity the I/C should be located behind it.
Set the pinion 1 degree down at the rear end. Check you drive line angle to see that your drive shaft isn't in a bind.
The T-arm usally works best when its pointing up just like the control arms. Postion it in the upper mounting holes. You then use the adjustable rear part to set the rear pinion angle.
stock springs are ok frt and rear. shocks depend on how serious you get. You do need adjustable type.
On drag radials you want to hit them hard and hold them to the track as long as possible.
Old 09-02-2012, 10:39 AM
clebmotors's Avatar
I tried everything from idle to 3500 and was spinning on everything but idle. No wheel hop best run was from idle lol
Quick Reply: need help, 1.9 60ft. with over 540 hp/tq
