13.56 @ 103 Bolt on LT1 good or bad?
Old 09-04-2012, 01:16 PM
Smoke Em's Avatar
Default 13.56 @ 103 Bolt on LT1 good or bad?
60' ... 2.16
1/8 ... 8.78
MPH....82.21
1/4 ... 13.561
MPH ... 103.04
the car MPH 103.52 on another run with a 2.205 60' pass
pass made on NT555, not DR
i know that 60' is killing me, but what time is possible if i get that 60' down?
what would it take to get 12s they way i am now? mods in sig
Old 09-04-2012, 03:15 PM
z28hustle's Avatar
suspension parts could help you out big time
Old 09-04-2012, 03:18 PM
z28hustle's Avatar
LCA's w/ relocation brackets, sfc's, torque arm.. maybe a shift kit if you don't have one and a stall converter... 3.73's
Old 09-04-2012, 07:08 PM
whytryz28's Avatar
stall and gears
Old 09-04-2012, 08:41 PM
LS1rob00's Avatar
Originally Posted by whytryz28
stall and gears
This.
As well as some sticky tires.
Old 09-05-2012, 12:59 PM
1Bad97WS-6's Avatar
Stall/Gear/DR's like said above..
Old 09-05-2012, 03:13 PM
Mike Morris's Avatar
Nice job!
Old 09-05-2012, 04:11 PM
ULTIMATEORANGESS's Avatar
has your car been tuned?
Old 09-05-2012, 09:24 PM
z28241's Avatar
Nice job for LT1 and bolt ons! Either poor track prep or u have some water left on the tires. with ur power level and comparing to what my previous A4 LT1's are basically the same, id drive around the water and do a quick dry burn out. had 28lbs on streets and dead hooked.
edit, i also agree with the posts above as far as going faster
Old 09-08-2012, 02:00 PM
moge11's Avatar
the gear is FINE.. get 3600 converter, a TUNE, and Drag Radials, and Lower control arms with Relocation Brackets.
Old 09-08-2012, 02:36 PM
transamtom's Avatar
My 94TA went 13.4 at 102 with similar mods and a 1.97 60ft.
A stall,gears and some sticky tires might get you a 12.
Old 09-10-2012, 11:19 AM
blk/slvr02ss's Avatar
Stall,Suspension and a tune.
Old 09-10-2012, 12:00 PM
350znal's Avatar
on par with most a4's with same mods. i know my old a4 lt1 car with intake, ported tb, mid lengths, catback and mail order tune went 13.3's@104 on street tires with a 2.0 60ft
Old 09-10-2012, 12:48 PM
BAIN's Avatar
This! I got my old 96SS running 12.8's full weight with headers, 3400 stall, and drag radials without a tune.
Old 09-13-2012, 08:58 PM
StraightTimeStirrups's Avatar
What were your times/speeds at the 1/8 mile?
Joe
Old 09-14-2012, 06:17 AM
BAIN's Avatar
I had to go back to my old CamaroZ28 days for this
Stock stall.
60'____?
1/8____8.091_@80.33mph
1/4____12.948@102.26
With Midwest 3000 stall spinning.
60'____1.7
1/8____8.1_@_85.3MPH
1/4____12.86_@_105.2
Old 09-20-2012, 11:26 AM
TravisMcGill2000's Avatar
Goos times. With stall and tires it will wake up alot. I was running 12.3@108 with my bolton lt1. With little spray was running 11.2s.. I think i had more fun then lol.
Old 10-10-2012, 08:40 PM
Bersaglieri's Avatar
My Auto, 3.23, LT1 full weight with cold air/LT's/GMMG went 13.6 at 105.5. So you aren't too far off. Didn't have a ported TB, but did have a Madwolf tune. Runs were made with street tires and I ended up with a 2.2-2.3 60'
-Dustin-
Old 10-11-2012, 04:37 PM
96lt1m6's Avatar
There have been many previous to me to give advice... Props to a good ET.
My Lt1 with bolt ons:
Madtuner tune
PaceSetter longtubes
2.5" Xpipe w/ 10series flowmasters
1.6roller rockers
SLP lid w/fram filter
4.10 gears
BFG drs
no spare or Jack
BMR sfc
Lakewood LCAs
Crappy auto zone clutch
12.98 @ 106 3004'DA
You are doing fine however it is time to drop some cash.....
Quick Reply: 13.56 @ 103 Bolt on LT1 good or bad?
