surging ls1 2001 vette
Hi i have a 2001 corvette ls1 with a surging problem i have just drilled the throttle plate and the idle has improved but still bucks down the hwy almost undriveable
have done maf sensor,o2 sensors,tcm module and pcm still no improvement has this happened to anyone or anyone could guide me to the next step im am now out of ideas
you might want to check for a vacume leak, somtimes you can spray carb cleaner around the intake and vacume lines and listen for a change in ideal, i wouldnt have drilled a hole in the throttle plate you might have added to the problem and might now have to get a tune to compensate for the extra air going into the engine. did the surging hapen after you drilled the throttle body or was it already doing it before you drilled?
you might want to check for a vacume leak, somtimes you can spray carb cleaner around the intake and vacume lines and listen for a change in ideal, i wouldnt have drilled a hole in the throttle plate you might have added to the problem and might now have to get a tune to compensate for the extra air going into the engine. Did the surging hapen after you drilled the throttle body or was it already doing it before you drilled?
The only reason i drilled out the tb was i saw post on this site to do so and it did help the idle but my drivabilty problem is still there
and i have checked all over for vacum leaks and none were found
