what gap for ngk t-55 for a 12 to 1 compression 418 ls3?
Old 09-10-2012, 10:27 PM
82cetuner's Avatar
Default what gap for ngk t-55 for a 12 to 1 compression 418 ls3?
just like title says what would you guys recommend someone told me.35 or .30?
Old 09-10-2012, 10:44 PM
Grr
Grr's Avatar
thats a pretty hot plug for that application, I would suggest a BR7efs at .35
Old 09-10-2012, 10:48 PM
82cetuner's Avatar
I had TR-6s in there before they are one step colder can I get the BR7efs at any auto store?
Old 09-10-2012, 10:50 PM
82cetuner's Avatar
my car is also not boosted I thought these plugs were for boosted or bottle applications I am all motor
Old 09-11-2012, 12:06 AM
bww3588's Avatar
Boost or higher compression...either way cylinder pressures are what your fighting. A hot plug like the 55 will really limit your timing. I used the tr 6's in my 11.5:1 ls1 and it was fine.
Old 09-11-2012, 01:01 PM
Sales@Tick's Avatar
Use a TR6 or a AR103. Gap at .040.
Old 09-11-2012, 03:18 PM
litle88's Avatar
I had the tr6's gapped at .40 BUT I had this annoying misfire! Talked to a few shops from all over abd one Jannety shop knew what I was talking about and said to get rid of them abd use AC Delco 41-104's. I threw them on and I see a MAJOR improvement. Gapped at .40 as well. It's a plug with the same heat range as a tr6 but it's an iridium tip. Just my .2
Old 09-12-2012, 07:23 AM
Sales@Tick's Avatar
A comparable Denso plug would also be fine to use which IIRC is also an iridium tipped plug and would work well in a N/A application.
Old 09-12-2012, 12:49 PM
Gray86hatch's Avatar
I run tr6 at. 035 revs 7500 no problem
I would also look at your plug wires
Tim
Old 09-12-2012, 02:06 PM
Keep the timing around 28-29 and they should be fine.
Old 09-12-2012, 04:19 PM
litle88's Avatar
31* was the sweet spot for mine when it was getting tuned at Straightline. At first I was like whaaaa but it's what it liked and I ran with it. Maybe that's why I has that miss? I don't know but it's cured with the acdelco 41-104's.
Old 09-12-2012, 04:38 PM
They dyno and real world race track will most of the time show two different things.
I have raced in really good air and 29 it slows in hot nasty air 29 works but 30 slows.
I would be concerned with that much in it if you were running it in really good air.
Tim
Old 09-12-2012, 04:46 PM
Jontall's Avatar
The OE LS7 plugs would work fine and you wouldn't have to change them every year: ACDELCO Part # 41104
Old 09-12-2012, 08:05 PM
Sales@Tick's Avatar
Tim
Tim is right on here.
Even though the chambers on the square port stuff seems to want more timing advance than a comparable cathedral port head motor that is a lot of timing on that plug in that motor with that compression.
Play with it at the least and see what the car wants at the track.
Old 09-13-2012, 07:53 AM
82cetuner's Avatar
well this is a street car not a track car but I do drag race it
Old 09-13-2012, 08:43 AM
That dosnt really make a diff you load it hard in high gear. Your car but I would not run it like that
Tim
Old 09-13-2012, 12:40 PM
Sales@Tick's Avatar
MPH gain and loss at the track is the best tell tale sign for whether your car likes the amount of timing you are giving it or not.
Interestingly enough my car on motor ran faster at the track with the amount of timing used that made the least amount of hp on the dyno versus the amount of timing that made the most hp, but ran slowest at the track.
Old 09-13-2012, 10:43 PM
Mez
Mez's Avatar
I did some research on the TR55 and sent an email to NGK.
As an engineer at NGK explained it, the TR55 is designed to be gapped at .055"-.060. The reason is if you bend the ground strap to achieve .035" - .040", the it ends up looking like a "J" rather than an "L" which results in accelerated erosion because the strap is not parallel to the center electrode.
Buy the TR5 if you want to gap at .035" - .040".
As for the heat range, if your car makes ~100 hp more than stock, you may want to look closer at TR6 or if you want an iridium plug for longer service life, look at the AC Delco 41-104 (or equivalent). Autolite makes an equivalent which I hear is good quality.
Old 09-22-2012, 07:40 AM
offaxis's Avatar
82cetuner
have you milled your heads since you bought that motor?
The compression on it was only around 11.4 to 1 at most
Old 09-22-2012, 02:02 PM
LS6427's Avatar
TR55...gapped to .050
Quick Reply: what gap for ngk t-55 for a 12 to 1 compression 418 ls3?
