Install a TC-78 turbo
Old 09-12-2012, 03:07 AM
1loudTransAm's Avatar
Default Install a TC-78 turbo
i have a 01 T/A with 61k miles A4.
I going to a Turbo Setup soon. im going with a TC-78 turbo. with the exhuast mainfolds and pipping from
http://www.ebay.com/itm/LS1-Hot-Side...s&vxp=mtr#shId
I heard that cxracing on ebay is very good in intercoolers and pipping. will that setup fit the exhuast setup?
http://www.ebay.com/itm/Cxracing-Fro...00d19d&vxp=mtr
Im also trying to find a good oil return line, BOV, Wastegate, Boost Controller, and etc. whats good on our ls1
my Trans is build with a 3800 Stall. any help will be good
& im planning to run around 8psi @ 500rwhp with also a ls6 cam and 317 heads
Old 09-12-2012, 05:11 AM
mightyquickz28's Avatar
Although my app is an LT1/TC76, I used the CXRACING kit for my piping to good effect. The pipes and couplers were fine but the T-Bolt clamps were so closely spec'd to the 3", you 'really' need a buddy to help hold them closed while you start the nuts on the T-bolts.
Here's where I got my oil lines..
http://www.taekwondoplus.org/z28/Tur...oOilSystem.htm
There are several places to get the BOV, WG and controllers.
I got my WG(Turbosmart 38mm) from Forcedinductions.com
I got my Tial 50mm BOV from some internet site(can't remember where)
I got my AEM TrueBoost Electronic controller from Jegs.
Congrats on the new kit! Sounds like you're going to have fun and scare your passengers.
Old 09-12-2012, 08:45 AM
Sweet_SS's Avatar
Took measurements of both and had EVCO make mine. Make sure to use at least an -10AN fittings and line for the return and at least a -4AN fittings and line for your feed. You will need to drill and tap your oil filter housing. You don't have to, but I had a fitting welded to my oil pan.
BOV's: I'm using Tial 60mm
#1 - Tial (hands down)
#2 - HKS SSQ
Wastegates: I'm using Precision 39mm
#1 - Tial
#2 - Precision
Boost Control:
I'm using an BLOX MBC...knock off to the Hallman.
Alot of people are using the AEM True boost controller or the AMS controller.
Old 09-12-2012, 09:08 AM
607motorsports's Avatar
I'm running a very similar setup on my 02 SS. You will probably hear alot of guys knocking that ebay hotside due to fitment issues and whatnot. I have one of the original PTK kits that those ebay kits were made from and I still had some fitment issues I had to battle along the way but really nothing I felt was too horrible.
I modified my kit a bit and did not run the downpipe, instead I opted to make my own and dump it after the k-member.
I'm running a Hallman manual boost controller, Synapse BOV, and Precision 46mm wastegate and am currently sitting at a solid 13psi and mid 600's. Have fun man nothing quite like a boosted V8 from my experience
Old 09-12-2012, 01:27 PM
thanks guys for your infomation on the kit. & 1 more question, will the intercooler kit and the hotside kit will fit together? the links above
Old 09-12-2012, 02:02 PM
Ryans99ls1's Avatar
My build thread might be of some help.
https://ls1tech.com/forums/forced-in...-page-3-a.html
careful of that ebay hotside.. a lot of people who run that have had to modify it to get a good fit.
Old 09-12-2012, 03:50 PM
Hey Ryan, how much boost are you running on your TC78 right now to put down the 630 number? just curious
Old 09-12-2012, 06:35 PM
Ryans99ls1's Avatar
its right around 10lbs when it makes 630. by redline its closer to 9lbs but its still making the same power
Old 09-12-2012, 10:57 PM
thanks
Old 09-13-2012, 01:52 AM
This is what im getting for my turbo setup
please look at it.
Exhuast - http://www.ebay.com/itm/LS1-Hot-Side...sories&vxp=mtr
Intercooler Kit - http://www.ebay.com/itm/Cxracing-Fro...004765&vxp=mtr
Walbro 255L Tank Pump Kit
Tail 50mm BOV
Precision 39mm Wastegate
Fast 46Ib Injections
AEM Tru-Boost Gauge
is there anything else i need for the turbo setup
Old 09-13-2012, 03:02 AM
and a turbo http://www.summitracing.com/parts/TNT-11535/
Old 09-13-2012, 05:36 AM
Dang! That's awesome that it's all setup! I had to do each single piece of my kit (other than the Hotside created by Realquick) by hand, test fit, cut, refit, cut, refit, etc. I had the abs of a gymnast just from getting up and down under the car, lol.
Sounds like a sweet deal man. I saw some folks post that there may be adjustments to the fitment but looks like you're miles ahead by getting that kit.
please look at it.
Tail 50mm BOV
AEM Tru-Boost Gauge
Old 09-13-2012, 08:46 AM
If it were me man I would change up your setup just a little bit. I would personally go with an Aeromotive 340lph pump over the Walbro just because it will offer a bit more potential down the road. Also i'd go with some 60lb injectors as those 46's will max out pretty quickly.
You will also want to add a few things like a catch can setup as you have to remove the stock PCV setup on a boosted application. Also I would wrap every inch of the piping on the hotside with some DEI wrap and on that hotside the plug wires are very close to the pipes so get some DEI fiberglass plug sleeves and metal zip ties to keep the wires off the headers.
Old 09-13-2012, 08:53 AM
I've seen a few mentions of the 340lph here and there. How was the installation? Any special steps needed for this upgrade? Did you improve the gauge of the wire going to the 340? How's your fuel pressure with the pump change? Did you have to utilize a AFPR to get the fuel pressure in line with the correct settings?
THanks,
Dave
Old 09-13-2012, 09:14 AM
THanks,
Dave
You should really always upgrade your wiring when doing an aftermarket pump. I just did the Racetronix hotwire kit, perfectly simple and straightforward.
As far as the install it's basically the same procedure as the Walbro. You need to modify the cup a bit but other than that it's the same process. If you search on here there are a couple writeups of the install with pics. I used those when doing mine and had zero problems at all. Had the entire thing done in a couple hours time. Definitely recommend doing the "trap door" though... dropping the tank is ridiculous on these cars LOL.
I'm running stock fuel lines, no return system (yet) and no AFPR and my car idles and drive like stock... when not in boost
Old 09-13-2012, 11:09 AM
Thanks for the tips!
Old 09-13-2012, 01:19 PM
thanks for you guys helpon my turbo setup build. im trying to make everything 100% without missing or messing up anything.
im switch some items that you guys recommened.
Injections - http://texas-speed.com/p-189-fast-60...impedance.aspx
Aeromotive 340 Stealth In-Tank Fuel Pump - Center Inlet, from Speed Inc.com
Catch Can - http://www.ws6project.com/user_stor/...oducts_id=1787
Wraps - http://www.designengineering.com/
if there anything missing please let me know. thanks
Old 09-13-2012, 01:28 PM
thanks for you guys help again.
Old 09-13-2012, 01:30 PM
thanks for the recommened stuff to get
Old 09-13-2012, 02:38 PM
No problem man, I just did this whole project over last winter on my car so it's still fairly fresh in my mind. Have you thought about whether you are going to do speed density or keep the MAF for tuning?
Quick Reply: Install a TC-78 turbo
