stock 6.0 or 408 pump gas motor. need alot of torque and help
Old 09-15-2012, 07:37 PM
ratgun's Avatar
Default stock 6.0 or 408 pump gas motor. need alot of torque and help
wanting to build pulling truck. need a motor with good torque. parts i have so far are lq9 short block 317 heads and trailblazer ss intake. I want to use all of parts listed. what comp. should i run for pump gas 93 octane. or should i run e85 with higher comp.
Posted from LS1Tech.com App for Android
Old 09-15-2012, 08:27 PM
Tainted's Avatar
Theres a ton of factors to consider. For a cam od very highly suggest having someone like Pat G custom spec one for you. Have the heads ported and milled, supporting valvetrain, longtube headers, free flowing exhaust.
Old 09-15-2012, 09:01 PM
backdraft408's Avatar
what hp or tq are you looking to get?
Old 09-15-2012, 09:29 PM
ratgun's Avatar
it's goin to be a stock class so has to have manifolds. not sure on hp and torque budget build maybe 500 ish ?
Old 09-15-2012, 10:15 PM
Tainted's Avatar
Youre not gonna get that on a budget, and on stock manifolds forget it.
For 500rwtq youre going to need either forced induction or a built na motor
Old 09-15-2012, 11:02 PM
LS1T56FTW's Avatar
^ I don't follow? If my mild build 346 cube LS motor can make 419 torque, I don't see how a 408 could not make 500 torque (with the proper setup obviously).
Old 09-15-2012, 11:27 PM
garygnu's Avatar
talk to Pred-Z for a torque cam.
Old 09-16-2012, 03:20 AM
Sales@Tick's Avatar
That's a tall order on stock manifolds no matter if you had the collective cam timing prowess of Pat G, Ed Curtis, Brian Tooley, Geoff Skinner or Harvey Crane himself specifying the profile.
Old 09-16-2012, 09:17 AM
ratgun's Avatar
if not 500 what do u think? I was going to port manifolds out my self . what about plus 5 dome pistons with 317 heads ?
Old 09-16-2012, 11:16 AM
wildcamaro's Avatar
Get the compression up by milling the heads, get a good port job on the 317s. Port match the manifolds bc there is plenty u can remove. If you can use any stock ex manifold I suggest c5 z06 corvette manifolds, I saw a dyno test where they matched some shorty headers. I have a set I would sell you cheap if your interested. Def keep that trailblazer ss intake for max torque.
Old 09-16-2012, 11:39 AM
ratgun's Avatar
pm sent wildcamaro
Old 09-16-2012, 02:10 PM
ratgun's Avatar
u guess the ? is stock strock or 408 ?
Old 09-16-2012, 02:13 PM
Sales@Tick's Avatar
Go with a 4" stroke no doubt.
You're going to need something way out in left field on the cam timing.
I'm not even going to attempt to try and throw a profile out there because it will be followed by 5 posts asking why does it look like that and that will never work. If you're interested in this profile shoot me a PM, E-mail or call the shop tomorrow from 8-5 EST.
Quick Reply: stock 6.0 or 408 pump gas motor. need alot of torque and help
