Twin turbo GT45s....416ci or 427+ci???
Hey guys,
Here's my dilemma....
I'm using a pair of ebay GT45 turbos to feed my LS3 powered fbody. I've already purchased a Callies dragon slayer crank from a forum member that I'll be using. I want to build a big enough motor to spool those turbos on the street without having to make the engine scream. Now I know that a lot of things like cam, torque converter, etc, etc all have a lot to do with how a turbo will spool but I'm just asking in general.
What size motor would be a good size for these turbos???
Options...
#1. Buy stock size (or +.005) pistons and build a 416ci.
#2. Send the block to RED and have Steve resleeve it and punch it out to 427-433ci.
Would option #1 be good enough or am I going to have to fork out the extra 2k to have the block resleeved for a bigger motor???
Also, what rods do you guys recommend that won't break the bank?
My goal is a minimum of 1000rwhp
Options...
I was also thinking about using the LSA heads but Richard @ WCCH said they do not benefit from the thick decks like the LS9s do. So I figured I will just port my L92s, replace the valvetrain and valves and install some LS9 gaskets with studs. I'll eventually upgrade to LS9 heads though.
instead of contemplating spending 2k to spool $500 worth of turbos, why dont you sell those turbos, maybe lose $200, and buy the correct turbos for whatever engine you build.
Math was never my strong suit but it seems to me like you would come out money ahead.
now, 1000whp on street. you sure thats gonna be enough power?
I would prefer to keep the LS3 block I currently have. The only reason I want to go bigger is to just help with spooling the turbos earlier. If I can get away with resleeving it for even more cubes then that'll be cool. Good idea though.
I see your point but im not looking at buying more expensive turbos right now. Im on a budget here. I asked if I could get away with a 416 And be good or if something bigger would be required. If a 416 will do the job then I won have to spend the 2k on the block.
It's going to be a track car but it's also going to be my wknd warrior so to answer your question...1000rwhp might be enough....for now.
Those turbos have 77mm turbines. Pretty big to have any hope of spooling but since you say its a track car, try it out and tell us how it worked. There is a local guy here in MN that used two china GT45's on a BBC Chevelle and ran it in the Dynomax power to the wheels challenge. Google it but I think he made upwards of 1500rwhp.
Either sell those and get something more in the efficiency range or prove us wrong.
The plan is to later upgrade the turbos with a pair of BB units that perfectly match my setup, but for right now the GT45s will be enough to play with. I've been wanting to see what kind of power these turbos can make in a "twin" application. A lot of guys have used them in "single" setups but not really on "twins". I'll definitely check back with the results.
Doesn't that turbo have a bigger turbine than the ebay GT45s? I could be wrong...
You wouldnt be able to tell the difference between a 416 and a 427. Spending 2 grand to do that is the biggest waste of money you could possibly imagine.
Those turbos will spool just fine on that cubic inch. If a 427 can spool a pair of borg warner S475's with 96mm wheels and 1.32 housings.... a 416 spooling a pair of those 83/77's with 1.01's shouldnt be an issue....AS LONG AS THE REST OF THE SETUP IS DONE CORRECTLY.
This setup will not make boost 200 rpm off idle. It will not act right with a 224/228 camshaft. It will need some converter and it will need a medium sized cam. Low to mid 230's @.050 on intake. Mid to high 230's on exhaust minimum.
Now. Why do you want this thing to spool so quick? A 416 makes a ton of torque on its own. Do you have the chassis and tire to be able to actually USE 1000 lb feet@ 4000 rpm/10-12 psi??? Ive driven cars that can do that... and its completely useless on the street.
Have reasonable expectations of WHERE you want the power to happen. It will make for a much more enjoyable driving experience. Having to worry about wrecking if you give it too much throttle all the time isnt fun.... at least not to me.
