injectors
Old 10-01-2012, 05:35 AM
trigger man's Avatar
Default injectors
Hey guys are 83 lb holley injectors big enough to support a 700-800 hp TT lq4 on e85?
Old 10-02-2012, 09:37 PM
Calypso's Avatar
Here's some info I found searching through threads:
I made 617/623 at 82% on e85. Also run 8an feed, dual walbro255's, 58psi base pessure. Hope that helps.
80s @ 65psi base, 755rwhp through an 80e @95% IDC on e85.
80lbs injector for turbo application is good for about 925 Crank HP at 80% duty cycle (pump gas)
Old 10-02-2012, 09:50 PM
typhoon1015's Avatar
They are borderline as said above, if you dont have them yet, look bigger.
I am at 767hp on 58psi base FP -10 feed at 15psi boost about 95% DC as well. I have a little more left but not much.
I8UR4RD's Avatar
no ***
Old 10-02-2012, 09:59 PM
Calypso's Avatar
Another example I found:
i have FIC 104lb injectors, i run them at 68base which puts them at 118lb injectors. i use them for E85 at 816rwhp i was at 80% duty cycle
Old 10-02-2012, 10:03 PM
silver_82's Avatar
do you have any means to raise the base pressure significantly? Id agree with typhoon1015, if you havent bought them yet, look for a diff set
Old 10-02-2012, 11:36 PM
skinnies's Avatar
We run the Seimen 80's to 850+ rwhp with enough pressure behind them, this is on e85 btw.
Old 10-03-2012, 09:55 AM
Calypso's Avatar
What pressure and DC? Actually I'm in the same boat as the OP. Have new 80lb Seimens and would rather not spend $$ on bigger ones if i can hit 750rwhp on E85 with these.
It brings up a good question. For a street car that only sees WOT for a couple seconds at a time, is it even a problem?
Or does running higher base pressure create too much heat & stress on the pumps/injectors for normal cruising?
Old 10-08-2012, 05:11 AM
That's a good proposed question Calypso! I havnt bought mine yet so i'm glad I checked here first.Holley makes a 120 lb also but I worry how hard would it be to get a tune on a lot of cruising.
Old 10-08-2012, 07:45 PM
Calypso's Avatar
Still curious if anyone has more info or opinions on this...
Quick Reply: injectors
