which regator and rails are you running?
Old 10-02-2012, 08:30 PM
Gfleck047's Avatar
Default which regator and rails are you running?
I am doing a 5.3 single turbo I was gonna go carb. But decided to go efi instead I now have a ls6 intake and was wondering what fuel pressure regulator and fuel rails are you running I am hoping to make 650hp out of my car on e85. And not sure on which rails and. Regulator to run. Any suggestions?
Old 10-02-2012, 08:59 PM
burbalanche's Avatar
fast rails and aeromotive boost reference regulator.dont know numbers but should soon hopefully.e85 also
Old 10-02-2012, 11:38 PM
skinnies's Avatar
stock rails, mallory 4305M regulator
Old 10-03-2012, 12:40 AM
alexcoreas's Avatar
Can we see some pictures?
If you don't mind.
Old 10-03-2012, 12:50 AM
skinnies's Avatar
I don't really have pics, the regulator is in my fender. Just use the earls stock rail to 6an adapter, then 6an line from regulator to rails. Depending on your stock line setup you can use those also.
Old 10-03-2012, 01:10 AM
alexcoreas's Avatar
Thanks for clearing that up. I was going to buy adapters also but had read they leaked, if your using them its good enough for me. Others suggested welding the damn fittings.
Old 10-03-2012, 01:11 AM
skinnies's Avatar
Just buy the updated adapter, they have and old style and new style. The old style has a plastic retainer clilp which people have issues with, the new style screws together and works fine.
Old 10-03-2012, 08:36 AM
robsquikz28's Avatar
link to this setup
Old 10-03-2012, 09:49 AM
Strokinit383's Avatar
Also running boost referenced aeromotive with stock rails.
Old 10-03-2012, 11:38 AM
westtexasbuff's Avatar
Aeromotive 13110 regulator, Holley fuel rails.
Old 10-03-2012, 11:42 AM
WheelsUp84z's Avatar
ls6 intake, edelbrock rails, 127lb injectors, aeromotive boost referenced FPR. E85
Old 10-03-2012, 12:17 PM
boostit5.3's Avatar
stock rails can be good to 1000 hp. ive seen some high hp setups in person, just drill and tap the stock rails and get some -an fittings. i wouldnt skimp on the regulator though last turbo car i had i got a fuel lab 1:1 raising rate regulator and never had a problem with it. just make sure you set base pressure with the vacuum line off.
Old 10-03-2012, 01:06 PM
Boosted Firehawk's Avatar
[QUOTE=WheelsUp84z;16778719]ls6 intake, edelbrock rails, 127lb injectors, aeromotive boost referenced FPR. E85
whats the rest of your setup? Return lines? what did you use or even have one?
filter?
Old 10-03-2012, 02:29 PM
T76s10's Avatar
Same here except no e85. Boost referenced regulator is really nice. Makes tuning fuel tables allot easier.
Old 10-03-2012, 03:48 PM
35thsscamaro02's Avatar
Fast rails and SX performance boost referenced regulator.
Old 10-03-2012, 05:00 PM
NSSANE02's Avatar
Summit rails, Aeromotive reg, trickflow filter.
Also used the regulator right off the stock rails for a while. Didn't look great but it did the job.
Old 10-03-2012, 05:56 PM
Ryans99ls1's Avatar
Fast Rails, Aeromotive boost referenced FPR, Lonnies dual pump kit, 80lb injectors, -8an feed -6an return, PTFE lines for E85 (ls6 intake)
Old 10-03-2012, 06:16 PM
67Firebird455's Avatar
I've got a magnafuel boost referenced unit on mine along with a Vic Jr. EFI manifold with Edelbrock rails.
Old 10-04-2012, 02:24 PM
[QUOTE=Boosted Firehawk;16778978]
filter?
Twin a1000 pumps, -10 feed that splits to -8 into the rail, then -6 to the regulator and -8 return to the tank.
Old 10-04-2012, 02:34 PM
Moderator
denmah's Avatar
ebay rails
parker push lock fuel lines
aeromotive regulator
Quick Reply: which regator and rails are you running?
