How do I get desired CR?
Old 10-14-2012, 03:46 PM
KingPin1094's Avatar
Default How do I get desired CR?
I am looking to get about 12:1 compression ratio out of my LS1. Im going to be buying TEA/TFS 215cc heads. What cc do they need to be for me to reach the desired compression? Also the thinnest head gaskets i could find were .04 and the entire bottom end is stock. Also as a side not, 12:1 CR is still able to run pump gas 91 octane correct?
Old 10-14-2012, 03:55 PM
Gunslinger09's Avatar
12:1 CR is going to be hard to do on pump gas.
Old 10-14-2012, 05:26 PM
litle88's Avatar
Your going to need a cam with some overlap so some of that compression bleeds out if you want to use 93, just my .2
Old 10-14-2012, 06:40 PM
I built a 496 BBC that had 11.5:1 compression and it ran good on pump gas.
What do you guys think would be a good compression then? and how would i get that?
Old 10-14-2012, 07:35 PM
Sales@Tick's Avatar
If the cam is big enough you can do it.
To get 12.0:1 SCR and have a DCR low enough to run on 91 pump you'd need to do these things:
59cc combustion chamber
.040 head gasket
239/244 112+3 would lower DCR
That would put you at what I would consider the maximum safe compression for running on 91 pump gas. It will probably like 26* total timing and not a touch more. The quench is nice and tight and you've got great compression. You'd be at 11.75:1 SCR and 8.65:1 DCR. Honestly that is still pushing it and you can go one of two ways to fix that. 59.5cc chamber would put you at 11.67:1 and 8.59:1 DCR or you could run 243/248 111+3 profile to put you down to 8.57:1 DCR and stay at 11.75:1 SCR.
To say the least that combination with the right supporting mods would run like a raped ape, but would require fly-cutting.
Old 10-14-2012, 08:11 PM
.040 head gasket
Thanks you really know your stuff
Old 10-15-2012, 10:52 AM
Sales@Tick's Avatar
Honestly for a street car I'd do something smaller than the 243/248 profile I mentioned. Even though with the 14.5 IVO that profile would have making it still make great torque in the mid-range it would still need 4.10-4.30 gears in a manual or a 4200-4400 converter in an automatic to compliment it.
If you could live with somewhere around 11.5:1 SCR the DCR with my Polluter V.2 would be a nice well rounded package that would make numbers very similar to the VRX5 TFS215 thread that is floating around here right now. You could even do the 234/240 113+4 we offer in my Elite Series of camshafts.
Old 10-15-2012, 11:57 AM
mark21742's Avatar
I'm running 12.5:1 on 92/93 pump gas in my 408
But 255/271 cam drops my dcr down to a friendly 8.22:1
Old 10-15-2012, 12:51 PM
Sales@Tick's Avatar
LS3 heads?
Great example though of being able to utilize high static compression with a large camshaft profile and having the right DCR for still being able to run it on pump.
Old 10-15-2012, 08:20 PM
litle88's Avatar
Ls3 heads, hollow gm intake valve and inconel exhaust with 65cc chambers, cam in my sig, GM Mls gaskets but my pistons have -2cc valve reliefs.
Old 10-15-2012, 09:20 PM
mark21742's Avatar
LS3 heads?
Nope, very worked 241 heads with 57cc chambers
Old 10-16-2012, 04:54 PM
Sales@Tick's Avatar
You did notice this was on a LS1 right?
65cc chambers are damn near stock let alone that head shouldn't even be thought about being used on a 3.9" bore.
Nice!
Old 10-16-2012, 05:14 PM
litle88's Avatar
Nice!
Damn excuse me, I guess I must of thought I was in the genIv section lol.
Old 10-17-2012, 01:54 PM
Sales@Tick's Avatar
I really have no room to talk, I screw things up all the time lol.
Quick Reply: How do I get desired CR?
