Saab 9-7X info
Old 10-14-2012, 03:47 PM
LeadfootDuramax's Avatar
Default Saab 9-7X info
I have been toying with the idea of picking up a Saab 9-7x for a DD. I am looking mostly at the 5.3i. I know several people on here have them or have experience with them.
Are there any particular problems with these? Is the AWD system problematic? The rear air suspension? I have read that arnott makes replacement parts for much cheaper than the dealer.
I just want to make sure there isn't something I am missing or any known problems that can make these a nightmare down the road.
Old 10-14-2012, 08:34 PM
99CamVanillaTop's Avatar
PM Dirty30 he had an ls2 but I am sure he is knows a lot from other forums.
Old 10-15-2012, 12:25 AM
LS7 Member
UTzo6's Avatar
I picked up one from a forum member as a daily. No real issues with them less a little buck from the drive shaft from time to time. Easily remedied, but i havent had the time. As you said, arnott makes air ride replacement parts that are relatively cheap. It's basically a trailblazer with different badges.
Gas mileage is ~15 with mixed driving. I just added a tune and efans and hope to pick up 2-3 mpg.
Old 10-15-2012, 09:19 AM
ORedRoc4's Avatar
If it matters, Arnott made quality air bags that I used for my P38 Range Rovers air bags. The bags were about $100-$130 each were simple to replace...
Old 10-15-2012, 11:35 AM
Curveball TECH
TRANSdAMn 2k's Avatar
How long did that efan install take? I read it should only be about 2 hours max but wasn't sure. Do you have video proof?
Old 10-15-2012, 03:55 PM
Pwebbz28's Avatar
They are nothing more than trailblazers with wood trim. The AWD's have problems with the front drive shaft causing the transmissions to go out.
Old 10-15-2012, 04:39 PM
really? How so?
Old 10-15-2012, 10:40 PM
Pwebbz28's Avatar
Something about the u joints drying out or getting in a bind putting stress on the tranny and burning up the clutches.
Old 10-16-2012, 04:54 PM
Dirty 30's Avatar
No, the most common issue with the AWD is the front axle splines going out and leaks, on the Aero models.
The 5.3i has a different front unit.
I love my Saab. I couldn't have a more perfect vehicle for me. The stock trans finally went out after 80k miles of hard and I mean hard launches with my 3600 stall and my old 4000 stall. 1.7 60' for just an intake, tune, efans, full exhaust, and stall 4800lb SUV isnt bad at all
Quick Reply: Saab 9-7X info
