true Ls6?
true Ls6?
Hey guys as i posted before im looking for ls6 heads and today a add came up on craigslist for a ls6 engine. If i could get it it would be great. My question is how can you tell if its a true ls6? i used the search tool but could not find anything.
this is the only discription:
Ls6 and t56 trans approximate 85000 miles out of Cadillac. Complete with all exces. And wiring harness
It will be very hard to tell with 100% confidence because, and correct me if I'm wrong, even if the numbers check out that it is a LS6 block and has 243 heads, it could really be just that, a LS6 block with 243 heads, but not have the LS6 cam ect... There was a small number of '01 & '02 f-bodes that came with a LS6 block, but that doesn't technically make the engine a LS6.
If all you are after are the "LS6" heads, then it really doesn't matter what cam and block it has as long as it has 243 heads on it.
