Making my car leave harder?
Old 10-22-2012, 10:05 AM
CameronVic's Avatar
Default Making my car leave harder?
Chevy 5.3, TH400, PTC 3200ish stall, Master Power 76mm, E85, 3.08 gear, and a 26" tire, 3800lb car.
Ok, here's the cliffnotes version. 2 weeks ago: Car left super slow (high 2.0s, to middle 2.1s) and would go 8.20s @ 87-88. Couldn't build boost at the line, would only footbrake to 2400. This is when the car was on 7 psi.
Wired up my two step, gave it 36* timing down low to build some boost at the line, and hopefully get it to come out of the hole AT LEAST in the 1.9s. Got it to build 4lbs at the line consistently with the twostep holding the footbrake to 2800 (started to push through at 2850, gonna try 2825 next).
Now the car pulls off scorching low 2.0s in the 60'! And one time, when I accidentally staged DEEP, it pulled off a neck snapping 1.97 60'! LOL. Playing with timing a few other places, and turning the boost up to 15psi, and now the car does 7.50-7.60s @ 101-103.
I don't want to put a brake, or nitrous on the car. I'm gonna call the guy who made my converter and see what he says, I'm trying to avoid pulling the trans. (because I'm lazy, and just don't really like pulling a trans with the car on jackstands and using a floor jack to drop the trans)
I've talked with a few intelligent minds about my issues. One person says I've got too much gear, another says I don't have enough. I'm leaning towards some 3.27/3.31s, but I'm not just gonna jump right into a gear swap if that won't do anything for me. So I figured I'd come on here and see what you guys have to say. Thanks!
Old 10-22-2012, 10:44 AM
Danny's Avatar
With a 3200 stall converter you should be stalling up more at the line. Are you sure that converter is built for your specific setup? A brake would come in handle as well. So if you have to pull the trans, I would install one.
Old 10-22-2012, 11:28 AM
CameronVic's Avatar
Yep, it was made specifically for the car/setup by PTC. I really don't want a brake because then I'll have to upgrade the rear end $500ish, and they're way harder on the trans. Plus a brake is what, like $700? Unless there's a DIY trans brake option. I'll probably have to pull the trans and get the stall loosened, and maybe shorter gears also, because I'm realy trying to avoid a brake, or nitrous to help from the hole.
Old 10-22-2012, 11:48 AM
Ryans99ls1's Avatar
you want to retard timing to build boost off the 2step. In a nutshell, by retarding the timing you are giving the turbo more usable energy (heat) to spool it. Once you leave the line, go back to your normal timing
Old 10-22-2012, 11:57 AM
CameronVic's Avatar
How much would you pull? And should I just pull it while the two step is engaged, then put it all back in?
Old 10-22-2012, 12:33 PM
Ryans99ls1's Avatar
I couldnt tell you how much to pull. Try searching it, i know ive read some threads where people have talked about how much to pull but i cant remember the numbers(its setup specific). I would just start experimenting in the driveway or a parking lot. youll be able to tell right away and once it starts spooling faster pull some more untill its where you want it.
Old 10-22-2012, 01:21 PM
Gingervitis Addict
slow67's Avatar
If your th400 is built, a transbrake should only be a valvebody swap.
I know Jake's Performance had an automatic shift transbrake they were testing, and I'm pretty sure it wasn't $700.
Old 10-22-2012, 02:17 PM
CameronVic's Avatar
Got it, thanks man.
Yea, there's one for $150 that does it by shifter position, which I don't know how that works, and all the others start at like high $500s. So that's Between $750 and $1250 if I went that route. I put a 34 element sprag in, and a full manual kit, other than that, it's bone stock. It even came with some water in the pan when I traded my old nitrous kit for it!
Old 10-23-2012, 05:31 AM
skinnies's Avatar
Maybe you need better brakes, my ltd is a glide, 2.73's 27" STREET tire(not drag radial), ptc 3200 converter, 7675, and a good boost controller. It will make 3600rpm once get building boost and loosens up the converter with no 2 step, and make around 8lbs and go 1.7 60fts consistently and a few 1.5's(mind you, on street tires, not drag radials). I had the check valve in the brake booster going bad, it would make zero boost and only hold about 2700rpm, go 2.3 60fts. With an upgraded check valve in the line and going to a 3.08 gear and 26x8.5 slick I'm able to make 14lbs of boost at ~3800rpm as the brakes hold a lot better now. Also on the transbrake it'll make 20+ lbs at 4000rpm.
Old 10-23-2012, 06:38 AM
pwrtrip75's Avatar
Send it back and tell them it dont work right and to restall it. If it was a 3200 they were aiming at tell them you want a 3800-4000 then maybe it will be right.
Old 10-23-2012, 07:11 PM
CameronVic's Avatar
A glide and 2.73s gives you like a 4.9 starting line ratio that's a little easier on brakes than a 7.6. I'm probably going I end up pulling the converter. Last thing I have to try is give it like 25* ATDC timing on the two step and see what that does.
Old 10-23-2012, 10:58 PM
Sales@Tick's Avatar
It will take forever to spool an auto by pulling timing out of it initially.
It seems this topic comes up once a week and I'm left searching for my own threads and words on this exact stuff each and every time.
https://ls1tech.com/forums/forced-in...-60-times.html
https://ls1tech.com/forums/forced-in...pool-time.html
Old 10-23-2012, 11:48 PM
skinnies's Avatar
I've had a th400 setup in the car also and still could get it to come up on boost fine. Buy a GOOD boost controller and it'll help you more than you will need.
Old 10-24-2012, 12:05 AM
CameronVic's Avatar
Megasquirt allows you to pull timing only when the two step is engaged, then imidiately throw it all back in. I won't have to pull timing with my timing table, just a drop down menu in my launch control.
Old 10-24-2012, 12:07 AM
CameronVic's Avatar
My current manual air compressor regulator seems to be holding it very consistently. I don't really have $1000 to buy an AMS one to make it spool faster.
Old 10-24-2012, 12:27 AM
CameronVic's Avatar
So what I'm seeing is manual cars seem to be the only ones to take advantage of anti lag?
Old 10-24-2012, 11:56 AM
Ryans99ls1's Avatar
yeah these 2 threads cover what i was getting at with pulling timing. i knew i wouldnt do good enough job explaining it so i didnt even try. Seems you have a good idea of what to try already. megasquirt should make things a lil better too.
Old 10-24-2012, 12:15 PM
87silverbullet's Avatar
Don't need an AMS 1000. Eboost2 works fine for right at 500 bucks
Old 10-24-2012, 12:35 PM
Gingervitis Addict
slow67's Avatar
Got it, thanks man.
On the one based on shifter position, it locks up as soon as you pull it into manual low, just like the old stage-right trans brakes for the 2004r. It releases when you shift back up to 2nd.
Old 10-24-2012, 04:07 PM
Sales@Tick's Avatar
Anti-lag or two step, there is a distinct difference.
No problem man! I just feel like a giant tape recorder sometimes.
Quick Reply: Making my car leave harder?
