91/88 mustang reswap 6.0/T76
Old 10-24-2012, 11:11 PM
1bad03snake's Avatar
Default 91/88 mustang reswap 6.0/T76
I built a 91 coupe with a 4.8L and was in the process of adding a turbo. I had the core support swapped and a few days later picked up another engine. So as you all know one thing leads to another and another and another... after picking up an 88 coupe in way better shape. I'm back at square one.
Before the core support
After getting her back I decided to pull the motor to paint the engine bay
I picked up a 302 turbo kit and some ls flanges
A few minutes with my sawzaw
I need to get my hands on a torch to make the ford ports round
Now on to the 88
Swap time
Pulled the gages out
Back on all 4's.. it took about 3.5hrs to get it swapped (thanks Tim for the help)
Mustang cross member modified for a turbo 350/T5 tranny mount
Here is a lifter from my 6.0L (I was told it had nothing wrong with it) It chewed the cam up pretty good.
All 8 cylinders looked about the same.
The motor and tranny are both getting a rebuild while I'm swapping parts back and forth from the 91 to 88
I bought paint to spray the engine bay and new caster camber plates
Old 10-25-2012, 08:36 PM
LS1PUNK's Avatar
Looking good man.
By any chance did u get that part number?
Old 10-25-2012, 08:39 PM
I forgot to look, but i have it in my tool box. Im delivering the 91 to her new owner tomorrow. When i load it up ill pm you
Old 10-25-2012, 08:46 PM
ronnieforrester's Avatar
On3 hot side ? you score it used- ive been thinking about the same thing instead on the truck headers on my 4.8 turbo fox swap.
Any other insight on adapting the fox kit ?
Old 10-25-2012, 08:53 PM
From test fitting everything in my 91 when it was still running it looked like it would fit with very little modifying. Other than the ls flange swap and maybe shortening the cross over I think It will fit just fine. I have 6.0 manifolds and all the piping just in case it doesnt. I'm off tomorrow so when I get up I'm going to a buddy's shop to work on the ls flanges. I'll post up picks tomorrow night
Old 10-25-2012, 08:54 PM
Cool. Thanks !
Old 10-29-2012, 07:08 AM
I should have the finished product by thursday
20 minutes with a torch and a swedge
I let a buddy of mine finish them up. I'm going to bring them to work and have them tig welded tomorrow
Old 10-29-2012, 08:34 PM
LS1PUNK's Avatar
Not bad.
Figure out what ur gunna do motor wise?
Old 10-29-2012, 09:17 PM
The motor will be done Saturday. I'll be off all week to work on it
Old 10-30-2012, 11:37 AM
I got the passenger side manifold welded up today. The flange got slightly warped. I'm going by a machine shop after work to get it straightened. Exner transmissions rebuild my th350 and added a manual valve body
Old 11-01-2012, 06:54 AM
Here is the semi-finished product. I'll drop it in the car this weekend to finish test fitting everything.
Old 11-01-2012, 08:25 AM
s10pro's Avatar
gls cant wait to see the fitment
Old 11-03-2012, 01:51 PM
I got the test motor in the car. I need a straight water neck and to plug the heater core lines.
Old 11-03-2012, 01:54 PM
Old 11-03-2012, 10:28 PM
TxFireman1972's Avatar
Looks good with the turbo sitting in there.
Old 11-03-2012, 10:32 PM
My new shortblock was finished up and delivered tonight. Im still waiting on my cam to come in
Old 11-06-2012, 07:35 AM
Fresh rebuilt trans by Exner transmissions
Old 11-10-2012, 09:38 PM
Tweek's Avatar
Any updates? Im really thinking about buying a on3 kit and going the same route.
Old 11-11-2012, 01:10 AM
The on3 kit fits good. I've been chasing parts and getting ready to install the cam/heads/ front/rear covers and oil pan. I should have some progress pics on monday
Old 11-15-2012, 11:46 AM
I finally got a day off to work on the car. I got the cam/lifters installed. Heads, oil pump,windage tray and pick up all installed. I also pulled the factory 4 banger brake booster and installed a 02v6 booster with a 94gt master cylinder
Quick Reply: 91/88 mustang reswap 6.0/T76
