Borg Warner
Borg Warner
Anyone know if this would work on a 4.8
http://www.ebay.com/itm/Brand-New-BH...7411b6&vxp=mtr
It's a T6 exhaust with a 5 inch outlet. The Compressor wheel measures 73.5 x 107.1mm. The turbine wheel measures 97.23 x 86.23mm. He shows it has a BW number 167713 with a 26cm exhaust housing, But Borg Warner shows the 166713 has a 32cm exhaust which is 1.30 A/R
Yeah I just got the heads I think ill finish porting them do a valve job and springs and see what they do. I have a few sets that im going to try just to see what is better.
So anyone have an opinion on what would be a better turbo choice this BW or a On3 76mm I already have some On3 .96ar units but was looking for somthing with a bigger turbine. Motor is a build 294ci forged pistons ect. currently with ported 706 heads, .6xx lift turbo cam, Its currently backed by a muncie 4 speed but going with a Glide and a 4000ish stall. I also have a garrett 4202 I could get from a buddy. Motor will be running a blow thru e85 setup. Thanks....
If you wouldn't mind post/pm those links to those other turbos. I would like to see them has those prices are way less than BW sells them for. I see that the one on Ebay says it's a BW turbo, But I see no part number on the compressor cover or a factory tag on the bearing housing. That's what alot of overseas stuff looks like. Not saying it is, Just curious.
