bent my studs on s60
Went to the local drag strip today and after making 3 passes launching on limiter, I went back to the pits to change my wheels back to the street wheels and I noticed that my studs were now screwed up. I just ordered a set of ARP studs in the same size (1/2"x20) from Summit, but then I read somewhere that they need to be the screw in type not the press in type? Can anyone verify this? If so I will have to call up summit and get different ones. Ive attached some pics of the bent studs. Thanks in advance!
Kleeborp the Moderator™
This isn't the first time I've seen something like this, and I'm not surprised it happened here either. Anyone doing hard launches should upgrade their studs to ARP, no questions asked, even on an aftermarket rear like this. It's cheap insurance. I didn't even see markings on the studs that came with my Strange 12-bolt, so I have no idea how strong they were. Since I wasn't using my car for drag racing, it was never an issue, but I wouldn't have thought twice about replacing them if I was.
At least they only bent instead of shearing off...consider yourself lucky.
I really think lug style is a contributor. I'm running stock diameter and length Moser studs that have seen 7 years of launches on slicks off the limiter, but running the shanked lugs that came with my Bogarts. Have never had an issue.
OP wasn't hooking particularly hard that day either, and his S60 lugs are quite beefy (much moreseo than mine) though not ARPs, but he is running a regular lug. Theoretically the shanked lug is going to have a larger surface area to absorb and distribute the force through the stud on the lug to wheel surface.
yeah we came to that conclusion from how NHRATA01 has been launching on slicks with shank lugs for like 100 passes now on stock size studs with no problems and I have 6 passes on my new rear with bent studs. lol
