questions on my 6.0 s472 build
Old 10-30-2012, 12:34 AM
Quickfrc's Avatar
Default questions on my 6.0 s472 build
Ok guys I thought I had this all figured out. But I don't. I built a stock 6.0 with fresh bearings and filed rings, head studs, ls1 can and intake. I just bought a s472 t6 1.32 ar. I'm running no intercooler and meth with 91. Will this work?
Old 10-30-2012, 04:25 AM
Luke Skyjacker's Avatar
Why are you doubting it?
Old 10-30-2012, 06:15 AM
Sarg's Avatar
96mm turbine?
Old 10-30-2012, 06:36 AM
Quickfrc's Avatar
Sounds like the turbine is a little big.
Old 10-30-2012, 06:39 AM
Quickfrc's Avatar
Originally Posted by Sarg
96mm turbine?
Yes. It seems as if the intake temps will be cooler, but might have a lot of lag. I'm not sure, I don't see many running this turbo.
Old 10-30-2012, 06:47 AM
Sarg's Avatar
It will spool it fine. What are your actual goals. The problem is you are going to run out of steam big time up top and start really getting inefficient which means high intake temps. If you are just going low boost it will likely be fine.
Old 10-30-2012, 07:06 AM
turbocamaro125's Avatar
96mm wheel will spool fine also
Old 10-30-2012, 07:09 AM
LS1Tech Sponsor
hellbents10's Avatar
the 72 can take it close to the edge. On the LQ4 we were playing with on E85 the 72 was not enough to bend the rods, we went to a 75 and were able to bend the rods.
Old 10-30-2012, 07:17 AM
Quickfrc's Avatar
I would like to hit 700 through a 700r4 and a custom cam. Possible?
Old 10-30-2012, 07:24 AM
Quickfrc's Avatar
What kind of power were you making
Old 10-30-2012, 12:06 PM
redcam622's Avatar
Yes possible..stock parts will be on the edge as will the 700r4..not from the hp..from the torque.
Quick Reply: questions on my 6.0 s472 build
