Notices
wtb: Boost heads, AFR, TFS etc
Old 10-31-2012, 04:11 AM
jt76's Avatar
Default wtb: Boost heads, AFR, TFS etc
As the title states.. interested in AFR 225, TFS 220 235 etc etc Going on a boosted motor. thanks!
Old 11-02-2012, 02:08 PM
jt76's Avatar
bump, cash in hand
Old 11-05-2012, 03:21 AM
jt76's Avatar
bump again for FI FRIENDLY heads!
Old 11-05-2012, 03:24 AM
rcsfastmonte's Avatar
what about a set of LSX7 heads? are you going to the 6 bolt block?
Old 11-05-2012, 03:28 AM
jt76's Avatar
No, i have a regular 4 bolt Iron LQ9 block, also looking to stick with cathedral ports. Thanks though.
Old 11-06-2012, 10:30 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
what chamber size you needing?
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 11-06-2012, 12:47 PM
jt76's Avatar
I think something high 60's would be best. I have stock height forged pistons, currently running 317 heads.
Old 11-07-2012, 04:31 PM
jt76's Avatar
bump!
Old 11-08-2012, 11:35 AM
lsxmini's Avatar
I have a set of afr 205 heads, 66cc. i also have the matching custom ground comp cam and a complete set of 42lb cobra injectors. I would like to sell it all as a package deal since they are made to work together.
Old 11-08-2012, 03:24 PM
jt76's Avatar
205's are a little small... looking for something over 220.. thanks for the response though.
Old 11-11-2012, 12:36 AM
Closed ex-Sponsor Account
matt510's Avatar
Would you be interested in ported/machined 317 casting heads or only looking to buy aftermarket?
-Matt-
Old 11-11-2012, 05:01 AM
jt76's Avatar
Looking for aftermarket casting for the thicker deck. Thanks though.
Old 11-14-2012, 12:49 PM
jt76's Avatar
back to zee top
Old 11-15-2012, 11:52 AM
jt76's Avatar
up for today
Old 11-18-2012, 07:28 PM
jt76's Avatar
still looking
Old 11-20-2012, 04:00 PM
dschmittie1's Avatar
Here a buddy of mine is selling 225 AFR's
https://ls1tech.com/forums/eastern-c...r-partout.html
Old 12-16-2012, 06:57 PM
jt76's Avatar
Bump it back to the top. Almost had a deal but was a couple hundred away.
Quick Reply: wtb: Boost heads, AFR, TFS etc
