Need help badly
Old 11-01-2012, 10:13 PM
zxr9buddy's Avatar
Default Need help badly
Need help, well i rebuilt my 2001 ls1 pontiac ws6 ta and now when i start it and when it gets hot and i give it gas water blows out the raditor cap. What did i do wrong? Did i put the head gaskets on wrong and i just did how the instuctions told me.
Old 11-01-2012, 10:23 PM
Keith_Shapiro's Avatar
Sounds like an air pocket in the cooling system, flush it and see what happens! Unless I'm reading it wrong, what does your temp gauge say?
Old 11-01-2012, 10:25 PM
im-not-guilty's Avatar
I don't know what you used for head gaskets ..
But factory gm head gaskets .....
Have printed on them which way the go..do you remember seeing that?
Old 11-01-2012, 10:28 PM
zxr9buddy's Avatar
The temp is normal 190/200 but when i driving and everytime i hit the gas water comes out the overflow then it starts going up cause the water low. And i have flushed it and still comes out.
Old 11-01-2012, 10:29 PM
zxr9buddy's Avatar
I bought victor reinz gasket kit
Old 11-01-2012, 10:30 PM
zxr9buddy's Avatar
And yes they had the printed way to go on.
Old 11-01-2012, 10:31 PM
No smoke out of the exhaust right?? Did you flush it with the car running and a water hose in the radiator??
Old 11-01-2012, 10:33 PM
zxr9buddy's Avatar
No smoke and i bought the kit to flush it.
Old 11-01-2012, 10:37 PM
Hmmmm... Not sure I definitely thought it is air in the system and its not over heating. I would also think you would know if you put the gaskets on the wrong way. Not sure man
Old 11-01-2012, 10:42 PM
zxr9buddy's Avatar
Thank you . And i no i put those gaskets on rt. But thats what all my friends here telling me that maybe i messed up and now i am second guessing myself . But thank you.
Old 11-01-2012, 10:51 PM
Your not leaking water anywhere correct? Just blowing out of the radiator?? Does it stop blowing the water out if you let it run for a while? Or does it do it immediately? It could realistically on,y be a couple things for the cooling system I.e coolant temp sensor, thermostat, radiator (air pocket), and water pump
Old 11-01-2012, 11:08 PM
waterbug1999's Avatar
u turn your heater on to get that air pocket out? You squeeze some of the air out of the hoses while the cap is off?
Old 11-01-2012, 11:10 PM
Originally Posted by waterbug1999
u turn your heater on to get that air pocket out? You squeeze some of the air of the hoses while the cap is off?
Didn't ask because I figured he rebuilt the motor then this would be common sense....I'm still leaning towards an air pocket. Let us know
Old 11-01-2012, 11:18 PM
wildcamaro's Avatar
Before you do any of listed above get yourself a new radiator cap, I know some might think its crazy, but I have seen countless cooling problems solved by a new rad cap. It is the cheapest route at like 7-10 dollars to eliminate, its worth a shot. The springs in the cap lose tension and it allows coolant to blow past it. Just my 2 hope you get it fixed.
Old 11-01-2012, 11:24 PM
That is a great tip, that's why I asked if it is doing it all the time or after it warms up! We need more info!!
Old 11-01-2012, 11:33 PM
CHADsterss's Avatar
Genius! I bet this fixes his problem.
Old 11-01-2012, 11:38 PM
caturnbull1's Avatar
Had the same problem after i bought my car changed the cap and no more problem
Old 11-02-2012, 08:33 PM
zxr9buddy's Avatar
I changed the cap and still blowns out under the cap and comes out of the overflow. And when it cold and i leave the cap off and i go to start it blows a big stream out the radiator . Its got to b the head gasket wouldnt you think. I hope not but my lucksucks. Thanks everyone for the ideas.
Old 11-02-2012, 08:36 PM
zxr9buddy's Avatar
Nice t.a. I have the same looking one but the dam cooling problem really sucks.
Old 11-02-2012, 08:39 PM
zxr9buddy's Avatar
The only time it stops coming out if its almost dry and then its starts moving the temp up.
Quick Reply: Need help badly
