oil sending unit
Old 11-08-2012, 04:44 PM
1970 LSCamaro's Avatar
Default oil sending unit
Do I need the factory oil sending unit hooked up for the motor to run? I want to eliminate it and install the one for my gauges in its place. Can I do this?
Old 11-08-2012, 06:15 PM
leon phelps's Avatar
why not use both. it is simple to buy the correct plate to have an additional one near the fuel filter.
Old 11-08-2012, 06:26 PM
Nsty98LS1's Avatar
why the hell would there be a OPSU near the fuel filter? just curious?
Old 11-08-2012, 06:34 PM
I sent my wire harness out to have it made into a stand alone harness to use on my swap. It dont have a plug in it for the oil sender. Thats why I was askin.....if I dont need the factory one I will remove it and use my autometer sender
Old 11-08-2012, 06:47 PM
LS1MCSS's Avatar
Some people just drill and tap the block off plate, by the filter, and screw their sender in there.
Old 11-08-2012, 07:13 PM
74modified's Avatar
The one with the tap still in it is the original sending unit. It was broken anyway. The other one is the oil cooler bypass from near the oil filter. I drilled and tapped both for 1/8 npt. This way you can use whatever sender you need.
Old 11-08-2012, 07:20 PM
So the motor will run without the oil sender hooked up? Right?
Old 11-08-2012, 07:22 PM
LS1MCSS's Avatar
Correct
Old 11-08-2012, 07:39 PM
Thank you
Old 11-10-2012, 08:43 AM
Novas Forever's Avatar
My harness didn't have a plug for the oil pressure sender either, he said didn't need it. Bought the fitting to hook my oil pressure gauge line to it. No problems.
Old 11-12-2013, 04:23 PM
murderbird's Avatar
Sorry about posting my problem hear im new to the forum thing and have run out of options im having problems with oil gauge abs inop and some sorry of drive train noise all after a motor swap been through everything read every book replaced almost everything possible can anyone help
Quick Reply: oil sending unit
