k member removel
k member removel
I been thinking about upgrading my bottom end with katech rod bolts and wondering how hard it would be to do it inside car so I need to take the k member off I been searching but can't find it does anyone know where there's a write up on someone who's done this ...
You will probably have to leave the rack with the motor or disconnect the power steering lines. If you take the rack out with the k member you would need to disconnect the steering shaft.
When removing the bolts from the top does the engine get in the way? I have the motor out of mine at the moment and that’s the only thing I could see that might help.
