Looking for Mustang swap results with EFI
Old 11-11-2012, 07:41 PM
TxFireman1972's Avatar
Default Looking for Mustang swap results with EFI
I've read until my eyes run together, but having trouble finding what I'm looking for. I can find lots of fox bodies getting good results with simple solid combos of carb, intake, cam, MSD 6010, 150 shot, and maybe some head milling.
What I'm wanting to see is the results from a simple setup like those except running EFI. Basically stock motor, with aftermarket cam, LS1/LS6 intake, heads milled (or not), with the same small shot of nitrous. Those seem to be harder to find.
Old 11-12-2012, 10:06 AM
Coming up on 100 views and no replies? That's the problem I'm running into is finding simple EFI combo results. Carb combos are everywhere.
Old 11-12-2012, 04:30 PM
Capown's Avatar
MustangLS is running a pretty much stock setup in a SN95 car with a similar weight to a foxbody. I think I saw LS6 intake and longtubes with big converter running Mid 11.s
Old 11-12-2012, 05:27 PM
yeah his is one of the few I have been able to find lol
Old 11-12-2012, 11:40 PM
red 95 t/a's Avatar
Im doin a turbo fox rite now but my brother and I built a simple s10 with a cam only lq4 23x-24x duration,Vic Jr,proform 850,Msd, 4k stall and 3.73s it was 27xx pounds. No spray as he's turboing it now. My cam only ls1 t/a with 150 hit of spray would honesty probably.not pull on it. It was crazy lil truck for how simple it was. Oh by the way it would blow the tires off at 60mph like Nutn . Hope it helps you in your quiestion . It's hard to find simple cheap builds on here. The simplest would be make a stand alone harness for efi and make your stock gauges work (cheapest) or aftermarket gauges
Old 11-13-2012, 06:52 AM
That's a good carb combo, but like I stated in the original post, I'm looking for EFI combo results.
Old 11-13-2012, 03:00 PM
MustangLS's Avatar
There have been a couple of builds like mine but like you said most don't post up results. Either they keep to the street or never really finish it. There is one guy local to me that went 11.43 @ 121 with an LS1 engine, ported heads, mild cam, headers, ls6 intake with factory EFI and HP tuners.
Old 11-13-2012, 04:44 PM
99MUSTANG5.3L's Avatar
I am running a bone stock 5.3/4l60e in my 01 Mustang and figure I should be high to mid 12's. No track times yet, hopefully this spring.
Old 11-17-2012, 09:25 PM
Its hard to stay EFI when you see pics (and results) like this:
Old 11-19-2012, 03:29 PM
MustangLS's Avatar
You can have a pretty clean engine bay with EFI if you use something like the Holley HP. Just wiring for the essentials. That's how I like it clean and easy to work on.
Old 11-19-2012, 04:58 PM
tired2valve's Avatar
cant recall the members name here but he has a lsx h/c/i, t56 in a old 240z
i think it was running 9's (idk i see to many lsx swapped cars that are fast to remember there names)
Old 11-19-2012, 04:59 PM
I agree. Yours is proof of that!!
Old 11-19-2012, 05:23 PM
topendrunner's Avatar
89gt stock lq4/stockls3 heads/stock l92 intake/mild cam 6 spd.
45x whp and 42x wtrq.
Spins third gear like first gear. From second at like 50 it will fry them and spin third till like 80. Thats on new 275 drag radials. It is cold as **** here tho so thats not helping. No track times
Old 11-25-2012, 01:27 AM
Blk4v00gt's Avatar
Sub'n for more results...
Planning a pretty simple build like this myself. Stock 6.0 lq4 w/ 317s in a 90 fox coupe. Planning to stay completely stock down to the exhaust manifolds and run a 2 1/2 x pipe and ls6 intake. Other then that just a stall and 150 wet shot so I'm curious where that would put me
Old 11-25-2012, 08:36 AM
soundengineer's Avatar
there is a much simpler solution....
figure out what kind of power people are seeing from their combos, relate it to 1/4 mile times based on weight and power.
I found this link a long while back...found it fun to play with... seems to be in the ball park assuming your suspension is set up correctly
http://vexer.com/automotive-tools/1-...MPH-calculator
the key with any setup, is the suspension...
I would be worried less about the motor specifics and more interested in the suspension setup.
if you cant plant the power, then it doesnt matter what motor combo is in it.
not only that, but transmission plays a big part too....
is it a t56? is it a th400?, is it a gllide?... all big differences in ET for the exact same engine combo
be worried less about the engine, start looking at the suspension needed to go fast as the stock rear and suspension doesnt really go very fast... poor Instant center, poor weight transfer, poor anti-squat.
Old 11-25-2012, 08:38 AM
oh.. .and for the reference....LOL
my combo should go low 10's on motor, low 8's on nitrous...
my cam is not even remotely close to small..LOL ....... 25x/27x duration @ .050
Old 11-25-2012, 09:45 PM
I do agree that all of those are important for sure. I'm just looking for combos/results and they can share all of the details that go with it.
I agree that the rear suspension can be improved on, but there are plenty of cars running pretty fast with a fairly "stock" suspension. Plenty of fox body cars running really good 60' times with something as simple as 90/10's and 4-cyl springs up front along with aftermarket lowers, 50/50's, aftermarket coils and maybe a bag in the rear.
A friend of mine locally running that exact setup with a LS1 (5.7) motor, heads milled, cam, intake, carb, MSD 6010, and a TH350 w/stall. Runs 10.7x on motor and 9.8x on a 150 shot. May not be a 8 second car but plenty fast for most.
Old 11-25-2012, 11:20 PM
83ripper's Avatar
Hey man real busy weekend. Ill send the pics asap sorry about that. As i told you before my car is an lq4 stock bottom. 5.3 heads. Cam. Vic jr intake. 6sp. Stock rear suspension. Coil over in front. All motor best pass 10.69@128. 1.50 60ft. Car has more in it.
Old 11-26-2012, 08:44 PM
72Elkytpi's Avatar
still getting my tune fixed, got the mail order tune from wait4me performance. Considering holley self tune but not sold yet.
408 LME LQ9 with 11.5:1 and T56
Hope its in the 10's
Attached Thumbnails Looking for Mustang swap results with EFI-ebay-008.jpg   Looking for Mustang swap results with EFI-ebay-007.jpg   Looking for Mustang swap results with EFI-ebay-010.jpg
Old 11-26-2012, 10:44 PM
What's not selling it for you...
It should be a no brainer to go with the holley ecu...
What can I do to convince you...?
Quick Reply: Looking for Mustang swap results with EFI
