TC78 on a 4.8/5.3- Horsepower/Backpressure
Old 11-16-2012, 01:42 AM
ronnieforrester's Avatar
Default TC78 on a 4.8/5.3- Horsepower/Backpressure
So I just bought a TC78 from Huron about 2 weeks ago and then I saw the thread about the bigger wheels available soon.
Sooooooo, with that being said I'm building a budget JY turbo set up for my fox body- The goal will be 140mph trap speeds and maybe a high 9 slip but its mainly a fun street car/Sat night car that gets beat on.
I know the 76/75 from Turbonetics or PT will make a ton more power with the bigger wheel but with the smaller displacement of the 4.8/5.3 will I do ok with the 68mm turbine wheel.
the car will never see any other engines other (large CI) than the JY specials.
My personal goal is to make 665whp - that's what my nitrous 408 Windsor made that I pulled out and sold to do the LSx swap.
basic setup will be
4.8
TH400 with tight converter
TC78- boost undetermined
E85
0411 PCM with HP Tuners
The fox weighed 2800 with my 408/5 speed combo
Old 11-16-2012, 11:43 AM
a-low's Avatar
From what ive been told and read here the concesus
is that theyre perfect for 4.8, 5.3s I think skinnies
has first hand experience with 5.3 tc78
Old 11-16-2012, 12:24 PM
o2camaross's Avatar
Skinnies is running a pt7675 I believe. I think you can reach your goal with the TC78, but you can reach it easier with something like a 7675 or T4 S475
Old 11-16-2012, 12:58 PM
Mightymike2000ss's Avatar
Location: Home town Clive,IA current town FORT BENNING GEORGIA
backpressure shouldn't be a issue with the smaller displacement motors. my buddy is running 14psi on his 76mm ON3 turbo stock LQ4 and just ran down a 681rwhp cobra lastnight. He had to turn his boost controller up a decent amount because he is having BP issues with the small turbo and bigger cubes. Car only makes 10.5psi on a 13psi spring.
Old 11-16-2012, 02:09 PM
a-low's Avatar
Yup he is now, i think he ran a tc before that
Old 11-16-2012, 03:42 PM
Twin turbo c5's Avatar
You'll do just fine with that setup. I had a 76mm with a 96ar exhaust housing on a 4.8 and it ran great and made plenty of power. It spooled a little slower than on my 383 it was on but still did fine. Just boost the hell outta of it !!!! To make up for the lack of cubic inches.
Old 11-16-2012, 05:14 PM
HydroStream6's Avatar
I went 136mph on a TC76 with the 68mm wheel on a 370 at over 4000lbs. In a Fox and on a 4.8 you can definitely go 140.
Old 11-16-2012, 09:39 PM
Thanks for the input so far guys...
Forgot to mention ill be using a GTP Turbo cam (similar specs to TU1) and 918 springs
Old 11-16-2012, 09:57 PM
LS1Tech Sponsor
Superman09's Avatar
TC76 or 78 should work awesome with a 4.8 or 5.3l, terrific turbos!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 11-19-2012, 03:01 AM
skinnies's Avatar
tc should be fine for your goals
Old 11-19-2012, 02:43 PM
6.0mustang's Avatar
the end of the tc78 seems to be 800hp... or atleast for me it is. got 25 degrees of timing on 20psi... e85 9.0:1 compression. 6.0L
Old 11-19-2012, 04:06 PM
rotary1307cc's Avatar
Why not go with something like the precision gts? Spool is going to be almost the same and the engine happier
I have had both
Old 11-19-2012, 08:37 PM
I have had both
I already have the TC78 and its also about $700 cheaper than the pte.
I was going considering selling the TC78 and going with the new turbonetics with the 75mm turbine.
Old 02-09-2013, 06:28 PM
831jd's Avatar
How much power did you make with your pt7675 at 17-18psi
Old 02-09-2013, 06:33 PM
831jd's Avatar
Old 02-09-2013, 06:40 PM
achieved my 140mph trap goal !
Old 02-09-2013, 07:46 PM
a-low's Avatar
Congrats! Now lets work on that 60'.
Old 02-09-2013, 07:47 PM
LS1Tech Sponsor
Superman09's Avatar
Terrific!
__________________
Old 02-10-2013, 02:14 PM
NemeSS's Avatar
Good stuff.
Think it can go 20+ psi on the e85?
What do u think its putting down thru theth400?
Old 02-15-2013, 02:19 PM
Originally Posted by NemeSS
Good stuff.
Just saw this- it only made 570ish blowing thru the converter- I had it tightened up and haven't re dynoed-
ricer calculators says 620-640whp to go 143mph
just got a 3 bar map sensor- debating on getting a retune with HP Tuners at 21 psi or Switching to MegaSquirt and a Borg S478 Turbo and make more power with less boost.
Quick Reply: TC78 on a 4.8/5.3- Horsepower/Backpressure
