LSx turbo mustang 8.93@157!!!
stock 6.0 with unported L92 heads
holley hi-ram intake
garret budget gt91mm turbo
18psi
car weighed 3050 with me in it
8.93 pass
http://www.youtube.com/watch?v=xpK8g...ature=youtu.be
another pass
http://www.youtube.com/watch?v=7Wken...ature=youtu.be
18psi
8.93 pass
another pass
thanks! i think i can get it sorted out. this was the first time out with a new rear suspension setup. need to get the stupid 90/10 shocks off the front and replace them with an adjustable shock.
its just a th400 with a brake and rmvb.
yes sir. best one of the night. to bad it got loose that run.
Do you have any pictures of the set up? How are you running the exhaust? Also, are you using Hptuners, stock pcm, stock wiring harness?
Wow....that is amazing! What fuel you running? E85? I am curious what others think about your cam choice. I run a pretty good size cam also. Seems that everyone always wants to run a "smaller" cam on the turbo's but yours seems to love the bigger cam. I would love to hear a video of it just idling in the driveway if you have any.
no idle vids.
the exhaust is shorty truck headers flipped with v bands welded on. 2.5
cross over. 5" dp split into two 3" pipes that run back through the k-member to the firewall and then turn down.
