370cid ls3 heads cam advice ?
Ok so I'm almost done with my auto swap on my z06 and was wanting input on if you guys think I should switch to a different cam? Here are the specs of my setup. Thanks
370cid
13.7:1 compression
Ls3 heads milled .040 stock runners
Stock ls3 intake manifold
Comp.244/.248dur .612/.615lift 112+2lsa
175 wet with nano
Tuned on 110
Trans
4l60e
Ss3600
3.42 gear
Lmk guys thanks
370cid
13.7:1 compression
175 wet with nano
Tuned on 110
Trans
4l60e
Ss3600
3.42 gear
Lmk guys thanks
Not really wanting to change it just didn't know if this would really hurt with auto vs m6 that's all and it's more of a weekend type Car. The car made just under 500n/a on a loaded dyno as is with m6. Just didn't know if anyone knew or had a better option or would this work fine
Your number sounds a little high on ls1 power most I have seen with afr heads and a pat g cam was 460-470rwhp with out dropping a **** tinning money them . Keep in mind I amnon a mustang dyno which reads 6% lower and I have unported stock heads and intake and my numbers are with avg amount if timing, we added more timin and kept pickin up more. every degree added 8 rwhp even past 30* so I know I need heads and intake I should be around 550ish.
110 all the time as I stated my heads are hurting me quite a bit and was that a dyno jet saw corrected what was temp outside etc all has plays a factor. My session no fan 110* shop temp 10% humidity. so ya my numbers aren't crazy high but there ok considering conditions and under 3k in the engine just saying nothing crazy and I know the numbers would be higher today's 50* weather
I'm gonna go full port job or tfs 225 and ya I agree should have been higher I thought as well but o well another reason why I was kinda asking is I'm wondering if I'm over cammed on the bottle it picks up awesome 187whpnon a 175 hit but on motor I expected more
Just spoke with pat g and he said that its damn good power on a honest dyno with stock ls3 top end on a 6.0 and he would just do heads. Said cams bigger than he would recommend do to street manners but if I can live with that dont change it
I'd have the ls3's ported as well as the intake. If you change to cathedral heads, factor in a fast intake or something similar. That drives the cost up as well.
If you stick with the ls3 setup, call Geoff@eps. He seems to have the ls3 style cam profiles nailed down pretty good.
