installing heads,cam,ok??how much hp??help
Old 11-21-2012, 06:55 AM
danyo's Avatar
Question installing heads,cam,ok??how much hp??help
hiiii everybody
after i bought heads and cam for my 1999 camaro m6, i need your ideas,advices and thought before i start.
first
1/3/4 headrs
catback borla
slp lid
85mm maf
intake,throttle fast 92
205 AFR heads with 64cc
MTI CAM S1 244/244/ 612:612,112
7.4 push rods
660 valve springs
with 3.73ratio basically, after mothe i will install 4.10, ok??
i want to put 27 or 40 cometic heads gasket.
my stock shortblock with 85000 miles.
what your thought about this project and what should i do?
how much i will gain horsepower
your frinds from bahrain,
Old 11-21-2012, 08:01 AM
Tainted's Avatar
power? not much, you arent really changing much.
4.10 gears, plenty of people switch to 4.10's, but with having 3.73's already you dont stand to gain much for the 1/4.
Thinner head gaskets, that depends on your PTV clearance, and the very small bump in compression would hardly be noticeable.
If anything you may have a wash for dyno numbers because the 4.10's arent very dyno friendly, yet they will help you with the 1/4, but still not by much.
Old 11-21-2012, 08:38 AM
danyo's Avatar
Really? Not much power,really?
From around 330 hp boltons
And now heads and cam and intake
All that On ls1 not much power,
And about from 3.73 to 4.10
My 3.73 soon will break because of that i will go for 4.10
Old 11-21-2012, 09:25 AM
arock24's Avatar
That's a big cam for stock cubes. It will be a top end monster but a slug down low. Heads and cam can net you close to 75-100 up when set up properly. Why did you choose this cam? What are your driveability goals? Also, what clutch do you currently have?
Old 11-21-2012, 02:37 PM
danyo's Avatar
I have no problem with driveability
And why i choosing this cam
I want cam just like ms4 or trex
A big cam
Thanks for respons
Old 11-21-2012, 02:51 PM
arock24's Avatar
Just be prepared to do a lot of measuring and fly cutting with that set up. You'll have some clearance issues.
Old 11-21-2012, 03:11 PM
96capricemgr's Avatar
awesome build if you want to be in a magazine.
Expensive joke if you want to car to be fast.
Old 11-21-2012, 03:43 PM
Tainted's Avatar
ohh I thought you had all this already and the things I had listed were gonna be your only changes.
if youre adding the heads and cam and have all those bolt ons you should expect a very healthy gain, im thinking you can make in the area of 450rwhp
but those donkey dick cams arent the way to go. sure they make high end power, BUT all that area under the curve and below peak is where the smaller cams are gonna be rowing by you until youre way up in thats weet spot and youre playing catch up.
These motors dont need huge cams to make good numbers and run a even better et
Old 11-21-2012, 04:02 PM
danyo's Avatar
I have Confuse with your words !!!!
Quick Reply: installing heads,cam,ok??how much hp??help
