Go SD or stay MAF?
Old 11-30-2012, 09:38 PM
VandykeT/A's Avatar
Default Go SD or stay MAF?
My heads/cam car is tuned with a 85mm slp maf sensor. I've been playing with the idea of having it retuned with a 100mm maf and a FASt toys lid since I'm redoing my exhaust to but I've read alot about tuning problems and loss of driveability. Since my car is mainly a track car but is street driven but only in warmer weather. What do you guys think about going speed density on a set up/situation like mine?
Old 12-01-2012, 08:52 AM
LSxPwrDZ's Avatar
I personally would keep a MAF on the car. Get a 4" aluminum pipe to run from the lid to the TB with flex couplers and then order a OEM LS3/7 MAF and cut a slot in the pipe to install the card style MAF. Now you have a 100mm MAF that cost you 1/3 of the store bought ones!
Then take a look at this link to place in front of the sensor to keep that driveability in check! This honeycomb will keep the MAF readings stable so the PCM can accurately measure airflow.
http://www.saxonpc.com/100mm-cells-for-100.html
Old 12-01-2012, 08:58 AM
06X6spdGTO's Avatar
Ive tuned a PRC227 head/SNL v.4 cam/FAST toys 104/100mm SNL MAF LS1 Firehawk and it has ZERO problems with driveability. Banish and other VERY Knowledgeable tuners have proven multiple times that MAF/VE will have better overall power than SD tunes where both can be applied.
Do it the right way and run MAF/VE unless you need to switch to a custom OS for 2bar SD on high boost applications..
Old 12-01-2012, 10:16 AM
LSxPwrDZ's Avatar
Overall power will not change actually. If the VE is properly tuned it will produce just as much power as the same setup on MAF. Ive done both back to back on the dyno and produce the same power.
The problem is alot of people get the filtering coeficients messed up and it'll cause erratic readings on either MAF or VE calculations and sometimes will give a little different ignition timing at various RPM. But ultimately afr and timing stays the same between both methods then the power output will be identical.
Might as well use all of the PCM's power though and keep the MAF so it has that extra source of input to calculate airflow.
Old 12-01-2012, 11:18 AM
VandykeT/A's Avatar
What kind of a adapter harness will I need to convert from LS1 to LS7. All I can find is LS2 to LS7. Would I need to buy a LS1 to LS2 adapter and then a LS2 to LS7 adapter? And I've noticed the aftermarkets have a raised spot on the housing to space it out. How would I make up for that using just the 4" tube?
Old 12-01-2012, 03:19 PM
LS1Tech Sponsor
Slowhawk's Avatar
I would Sd tune the car then tune in the maf. Actually that's the way cam cars should be tuned anyways. I'm not a fan of the card type maf's on f-body's. they have a small tuning window and I've seen a lot of variations with them. I'd prefer a vette 85mm mass air.
Old 12-01-2012, 03:25 PM
LSxPwrDZ's Avatar
If you wanted to mock up just like the aftermarket GM sells a MAF bung that can be welded to your tube and cost's ~$7. However I've not seen any issues without the spacer. It just keeps the MAF from protruding into the tube as much and will make it read slightly lower hz (Frequency) per g/sec of airflow. In your application it's not going to make enough difference. You run into issues with maxing the maf table out on some cars on the frequency side of things and this is when you need to pull the MAF out some to re-gain some headroom.
The screen/honeycomb is needed with the card style with either housing you go with. It'll read just fine properly setup.
Old 12-01-2012, 03:52 PM
VandykeT/A's Avatar
I've all ready ordered a Hitachi LS7 sensor, I've been looking at the spectre 9705 housing and will probably go with it, Its a 4" housing with the bung all ready made onto it for 30 bucks. I found the harness caspers 108125. Now since I'll be using a 4" tube instead of a 100mm will the 100mm honeycomb from the link fit the 4" housing? And which cell size do I need the 5:1, 6:1 etc?
Old 12-02-2012, 07:17 AM
LSxPwrDZ's Avatar
It really depends on the housing itself. Some measure 4" on the OD and some measure it on the ID. If you could get a better demension on the spectre housing then you could order the correct size. I've had good luck with the 5:1 ratio screens.
Old 12-02-2012, 11:06 AM
VandykeT/A's Avatar
It says 4" outside diameter but I'll order it and measure it and go from there. Thanks
Old 12-10-2012, 06:00 AM
01ssreda4's Avatar
SD and be done. Then your intake will look like this:
01ssreda4's Avatar
Quick Reply: Go SD or stay MAF?
