Which cam to go with?
Old 04-13-2004, 10:28 PM
Zach@Texas-Speed's Avatar
Default Which cam to go with?
i'm searching for the perfect cam... i would like a idle that is pretty close to stock (not very noticeable to others) but good hp and torque numbers, i'm liking the stealth series cams that mti makes but i know theres more out there.....any input wanted.......thanks
Old 04-13-2004, 10:30 PM
SMOKIN01TA's Avatar
look at the tr 212/218 or the 220
Old 04-13-2004, 10:47 PM
gonbad's Avatar
Futral Motorsports.
Old 04-14-2004, 06:57 AM
equandt's Avatar
Aren't we all?
Do a search for "stealth cam".
Some cams to research:
TR's OMC
LS6 cam
Lingenfelter's GT2-3
TR220-114 cam
MTI Stealth Cam I or II
Comp Cam's 212/218 or 216/220 grinds (various lobe profiles are available)
These are the cluster of little cams that may meet your requirements. There is a lot of info on these cams for you to search for and read up on.
Hope this helps.
Old 04-14-2004, 08:29 AM
JBsC5's Avatar
I was searching for the same thing..and have been very pleased with the end results of the TTP installed 224/224 .563 114lsa cam package.
Through the stock Titanium Z06 exhaust I don't think anyone who isn't a car fanatic could hear a difference..
Car runs like stock till you hit the go pedal..
I'm very pleased with it.
Something to consider.
Old 04-14-2004, 02:45 PM
Default Sounds Good
Thanks for the input, i'll look into these cams and specs before i make up my mind
zach
Old 04-14-2004, 03:05 PM
pdd
pdd's Avatar
TR224 114lsa
Old 04-14-2004, 03:21 PM
Cstraub's Avatar
Perfect Cam= Combination (IE comp/stroke/rod length) + Induction Flow Numbers + Intended Power Range. Right cam everytime.
Chris
