What fans for procharger?
Old 12-11-2012, 09:32 PM
sweet99ss's Avatar
Default What fans for procharger?
What fans do I need to keep the car cool with a procharger? I've heard the procharger fan doesn't work that well? I seen people replace the procharger fan with a spale fan? And than another little fan? What are you guys running?
Old 12-11-2012, 09:57 PM
35thsscamaro02's Avatar
Spal fans
Old 12-12-2012, 11:10 AM
sweet99ss's Avatar
Originally Posted by 35thsscamaro02
Spal fans
You have part #'s?
Old 12-12-2012, 06:32 PM
sweet99ss's Avatar
part #"s anyone?
Old 12-12-2012, 06:37 PM
Blackpanther99's Avatar
I believe Griffin also makes great fans.
Old 12-12-2012, 06:43 PM
I8UR4RD's Avatar
Why do people avoid using pushers vs puller on the S/C setups I wonder?
anyways....
the best price on the Spal fans is here:
http://www.a1electric.com/spal/faninfo.htm
Old 12-12-2012, 08:03 PM
LS1RedZ's Avatar
anyways....
How much is that dual spal fan setup? I'm curious, what are u running because I've got a f1a also. Price?
Old 12-12-2012, 08:31 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
I think pullers work better than pushers. From everything I've read, people with pushers end up having heat issues.
Old 12-12-2012, 10:53 PM
jastone's Avatar
Look in here.
https://ls1tech.com/forums/forced-in...-spal-fan.html
Old 12-12-2012, 11:39 PM
sweet99ss's Avatar
huh looks like alot more trouble with heat with prochargers than I thought there was... I was hoping one big 16" spale fan would do the trick. I'm thinking the best way now is to do a 16" spal on the inside as a puller and put a pusher on the other side on the driver side of the radiator
Old 12-13-2012, 06:29 AM
I never have problems with mine just buy the two pullers. I don't think pusher puller fan setups are a good idea. When I just had one fan it only got hot when it was 100+ outside and I was blasting the ac.
Old 12-13-2012, 06:30 AM
ramairetransam's Avatar
i was gonna post pics but my pictures are already posted in that link .
Old 12-13-2012, 06:46 AM
UNDER PRESSURE MOD
FYI, I have the single procharger fan, and my car does not get hot, even with the a/c on in the summer and stop and go traffic. I never saw temps over 200-205 degrees, which is fine considering I have a stock thermostat in the car.
Old 12-13-2012, 06:48 AM
Well your one of the few. Are you going by the stock dummy gauge or an actual one
Old 12-13-2012, 06:56 AM
UNDER PRESSURE MOD
I'm going off of actual logged data, not the dashboard gauge.
Old 12-13-2012, 02:50 PM
sweet99ss's Avatar
Huh I guess I'll try a 16" spal fan and if it gets hot I will look into something else
Old 12-13-2012, 03:11 PM
do two fans while your at it , the spal 16 and the spal 9 i think
Old 12-13-2012, 04:24 PM
LS1RedZ's Avatar
I think I'm just gona make my own shroud and use two of the spal fans. Put the small one above the procharger so it won't hit. My procharger setup wouldn't fit with the F1A.
Are the spal fans pretty low profile?
Old 12-13-2012, 08:12 PM
stealth355tpi's Avatar
Spal 16 and 9 here. Don't remember the part #'s off the top of my head.
Old 12-14-2012, 11:59 AM
gpr
gpr's Avatar
to double check, when using these spal fans the factory connectors plug directly into them?
Quick Reply: What fans for procharger?
