11.5 compression and boost-why not!
Old 12-21-2012, 06:53 PM
eb02z06's Avatar
Default 11.5 compression and boost-why not!
2010 C6 Z06 off the dyno. Car has A&A V3 Si trim, some shiny new Pfadt headers and a Alky Control Meth kit.
The gains are impressive to say the least-especially for 7.5lbs of boost.
Old 12-21-2012, 08:27 PM
Wicked69's Avatar
Well....on pump gas I would say your nuts. lol. That is pretty brave in my book. However, I was contemplating next year to throw a 5.3 together but use the 4.8 flat top pistons. That would give 11.5 compression if my numbers are correct. I would run pump gas E85 AND METH/WATER INJECTION also.
Pretty sick numbers though! It has to be on the ragged edge though on pump gas. That is some serious coin if she blows.
Old 12-21-2012, 08:52 PM
LilJohn's Avatar
11.5? You wuss... lol
Working out the details on Twin S472's on an LS6 with 11.8 that puts 520 to the ground on motor...
800 rwhp on 6 psi. Lol
Old 12-21-2012, 10:42 PM
jridenour31's Avatar
What fuel? I'm leaning more and more towards upping compression.
Old 12-21-2012, 11:32 PM
Louis's Avatar
It would make almost 700 with a larger primary. How does the V3 compare to a procharger?
Old 12-22-2012, 12:01 AM
Blackbird-WS6's Avatar
think mike norris did a A&A Vortech SC kit on a bone stock 2007 z06 and it dynoed at 648whp/600wtq
Old 12-22-2012, 06:10 AM
great421's Avatar
Default My $0.02...
OP -
I've heard the "You're Nuts!" comment several times here as well.
I ran with the stock CR (10.4) and 11 lbs of boost on my LT1 for 40,000 miles with zero issues - of course I did also use a LOT of meth to keep everything bolted together. However, when I turned up the manual boost controller to 13 lbs, that's when things started to go pear-shaped!
Have fun - good luck - Merry CHRISTmas!!!
Old 12-22-2012, 09:24 AM
LS1Tech Sponsor
Slowhawk's Avatar
Good job Arun. No reason not too. LOL Only problem is the LS7 block liner cracking. Seen that a few times in the past.
Quick Reply: 11.5 compression and boost-why not!
