Oil pans for turbo setup
Old 01-02-2013, 03:51 PM
01snake's Avatar
Default Oil pans for turbo setup
I have a lq4 that I'm putting into a mustang and have been told that the truck pans are too deep?
What pans do you guys prefer the ls1 or ls2 pans? High hp setup and diffrence between the two?
Old 01-02-2013, 09:00 PM
x275radial's Avatar
right from jegs or summit buy a gm performance pan it will now only hold 5qts and is only like 150 bucks and comes with windage tray dipstick and tube pickup and gaskets
Old 01-02-2013, 10:31 PM
01snake's Avatar
5 qts enough for 850rwhp?
Old 01-02-2013, 10:35 PM
01snake's Avatar
Link?
Looked on jegs and found one but had no gasket or pick up tube
Old 01-03-2013, 08:21 AM
9sectruck's Avatar
I would run at least 6 in any build, my personal car runs 7.5 quarts
Old 01-03-2013, 09:10 AM
Old Geezer's Avatar
Exclamation
That GM pan, [pt # 19212593], is the H3 Hummer pan, and has the same capacity as the truck pan...It's 8" deep... Right at the same depth as the truck unit.The difference is the contour of the front area... Has better x member clearance.
Here's a pic of the 2. The dirty pan is off an LQ4. [2005 Hummer H2]
Old 01-03-2013, 10:16 AM
01snake's Avatar
So the one jegs sells is no good?
And I should look at a ls2 pan?
Old 01-03-2013, 11:22 AM
9sectruck's Avatar
gto pans are front sump, I do not know what the TBSS are for clearance wise they be just like the truck pans
Old 01-03-2013, 11:34 AM
groundczero's Avatar
Look in the conversion section, but the the mustang swap people have used, CTSV, and 4gen F-bodies (I am running this with AJE cross member).
Old 01-03-2013, 11:51 AM
01snake's Avatar
Well I talked to team z who my k is made by and he said to use the truck pan
So I guess I am gonna roll that way. He said the other pans would have some clearance issues up front
Quick Reply: Oil pans for turbo setup
