Want to run a C6Z stock/lightly modded in Nebraska
I've had this race w/ my M6 GTO w/ @470rwhp against a stock C6Z and it wasn't pretty...a stock Z has the @the same rwhp and alot less weight to move.
If you were an A4 car w/ @460 and a good converter maybe from a dig...barely.
This a 6.0/stalled auto car w/ @460 IIRC and that Z is running him down hard at the end.
There is a member who owns a z06 and a TT GTO. It took 550+rwhp from a twin turbo gto to walk a stock Z06. Then a bolt-on Z06 beat the GTO.
I think a bolt on ls3 c6 would give you a run for your money.. C6z would rape you even if you had 500rwhp. They weigh like 3160lbs and dyno 460ish rwhp.. Better gearing and wider tires.
I wanted a base line as I will also be spraying (Yes I was going to tell who ever wanted to race me that). So I wanted to get a race lined up and then talk to the owner of the car because I really don't want my Nitrous setup exposed out here to the locals yet.. I would be running drag suspension with slicks/skinny`s and on the shot be roughly 600rwhp...
17.1@85 with 100 shot
I should be making at or just over 500rwhp with my stall unlocked, 1pc CF driveshaft, 3.70 gears, UD pulley, all the normal weight loss, etc. I've barely beat 2 C6Z's and got edged out by 1.
Trust me when I say you want to find a stock C6Z just to keep him close enough to make your before and after video interesting.
