lq4 swap plans & problems
Old 01-12-2013, 12:25 AM
LsXblaze's Avatar
Default lq4 swap plans & problems
Hey everyone, newbie to ls1tech... i go on this forum everyday and i finally registered.... anyways ive got a 2002 blazer extreme that i traded for and i have plans to do a lq4 swap..... upgrades will be....
lq4 block .030 over
wiseco pistons
callies compstar h beam rods
stock crank
ls3/l92 heads
ls3/l76 intake... port matched tb/ cable driven
custom cam... unsure maybe 22x's/23x's .58x/.59x 114lsa exhaust bias?
revised comp 918 springs
ls2 timing chain
arp hardware
h3 oil pan kit
cpw wiring harness/ecu
gmpp accessory drive system (paceperformance)
upgraded 4l60e
stock rear end for now
qa1 suspension
caltracs
im sure im missing a few things that i have planned but my biggest issues is finding headers for s10 swaps with ls3/l92 style heads.... can anyone point me in the right direction??? Also any other pointers or tips or recommendations will be greatly appreciated. I know it will not be a weekend project... probably be 2 years to complete everything so bear with me to see finished project... thanks in advance
Old 01-12-2013, 06:40 AM
LsXblaze's Avatar
Also my goal is to put down over 400 to the rear wheels... compression of about 10 to 1 for pump gas and daily drivability... anybody got and insight on something i should do differently??? heres a couple pics of the beast before the snow started to fly
Old 01-12-2013, 06:41 AM
LsXblaze's Avatar
here they are
Attached Thumbnails lq4 swap plans & problems-baby-blazer-xtreme-237.jpg   lq4 swap plans & problems-baby-blazer-xtreme-238.jpg   lq4 swap plans & problems-baby-blazer-xtreme-239.jpg
Old 01-14-2013, 01:05 PM
LsXblaze's Avatar
Nobody knows about D port headers for s10 swaps??? or will just the standard s10 swap headers work?
Old 01-15-2013, 06:44 AM
LS1Tech Sponsor
psiconversion's Avatar
You should have no problem putting down over 400 rwhp with that setup. Make sure you get the compression over 10:1 though. Also, what MAF are you going to run and what throttle body? I assume you are going drive by cable.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 01-16-2013, 10:34 AM
LsXblaze's Avatar
Okay so i need compression to be 10 to 1. would that mean milling the heads? and if so what would be my pushrod length? yes i will be running a cable throttle body 90mm. i believe that is what the ls3 intake is if i am not mistaken, unsure of the maf yet
Old 01-16-2013, 11:25 AM
cbrodine's Avatar
If you went with the LQ9 type flat top that should put you around 10.5 I would think. From what I've read the only diff between LQ4 and LQ9 are beefier rods and flattops...hence the 9.4 vs 10.5 compression diff.
Also, you could use a thinner head gasket for a few extra points worth of compression and not have to mill heads....just some ideas.
Old 01-16-2013, 12:31 PM
LsXblaze's Avatar
the only thing im worried about is PTV with the ls3/l92 heads. im looking to do forged rods and pistons... for just incase reason that i may go FI sometime down the road
Quick Reply: lq4 swap plans & problems
