AI 200cc or LE2 for a 355 lt1
Old 01-12-2013, 11:57 PM
1991camaro_rs's Avatar
Default AI 200cc or LE2 for a 355 lt1
hey guys i got a lt1 from a local guy for a 150 bucks, it need rebuilt and i figured i could play with the bolt on car this summer, try and put together a nice head's and cam 355 while i do that, nothing crazy but nice. So im not trying to start an battle between the two, im just curious what kind of number's guys have seen with AI 200cc head's, and one of there hotter cam's, and what have guys got from LE2's and one of there custom cam's. just looking for opinions on both, and down sides and upsides to both...if there is any down sides thanks guys
Old 01-13-2013, 12:22 AM
after doing some more research around 400whp seems to be the norm, and low 11's with good suspension, gear, and converter seem's to be the norm. so any difference in quality maybe would be a better question.
Old 01-13-2013, 02:03 AM
fbody93's Avatar
AI by far. Even the 190cc would work just fine for a 355
Old 01-13-2013, 08:11 AM
bowtienut's Avatar
I'm running AI's 200cc ported LT1 heads and a 228 duration cam from them on a rebuilt stock bottom. You can see the 1/4 mile numbers below. Keep in mind the car is about 500 lbs heavier than the fast F-bodies.
On the dyno, it was 425 SAE @ 6400 rpm with small Tri-Y headers and a locked converter. Recently, it dyno'd 420 SAE @ 6400 with 1-3/4" LT's and a non-lockup 8" converter.
No downsides whatsoever in the AI setup for me. I got a well-engineered top end setup worth the money.
Old 01-13-2013, 08:53 AM
RamAir95TA's Avatar
AI 200ccs on a nothing-special 383 build here. Results in sig.
The AI stuff is unbeatable IMO.
Old 01-13-2013, 10:44 AM
97lt1camaro's Avatar
I have a set of le2 heads on my car, if I had to do it again i would be purchasing from AI. Pm if you want reasoning.
Old 01-13-2013, 11:23 AM
speed_demon24's Avatar
I've had both and it's not a contest between the 2 quality wise and power wise.
Old 01-13-2013, 11:56 AM
Alex94TAGT's Avatar
I've used both LE and AI as well. I strongly prefer AI.
Old 01-13-2013, 12:30 PM
Rob94hawk's Avatar
AI, LE, who gives a crap. It all depends on who gets their hands on them afterwards.
robsquikz28's Avatar
Ive had both on my car and the exact same buid except head swap.
Ran 11.7s with le2 and 11.5s with the 200s. As for spray mid 9s was a cake walk on the 200s
Old 01-13-2013, 01:01 PM
Dave357LT1's Avatar
My vote is for A.I. tho you may go fast and turn into a internet hero
Old 01-13-2013, 01:03 PM
Man-Crush Warning
Shownomercy's Avatar
Originally Posted by Dave357LT1
My vote is for A.I. tho you may go fast and turn into a internet douche
Ya, fixed that for you
Old 01-13-2013, 01:21 PM
thanks guys, i have heard more about AI than LE, although everything i heard about both we great. AI seems like a good deal for the money.
Old 01-13-2013, 03:32 PM
Moderator
JasonShort's Avatar
I also am a big fan of AI's stuff. Being a mechanical engineer myself, the CNC and machine work on their heads is absolutely top quality!
Old 01-13-2013, 03:55 PM
96capricemgr's Avatar
The responses from
97lt1camaro
speed_demon24
Alex94TAGT
tell you more than the rest of us could.
There are other guys who have been down the same road and tell the same story, hvyss and 94zgreenmachine are two more who come to mind.
Old 01-13-2013, 09:39 PM
Awesome, has anyone gone ten's on a stock bottom end, or tens with a AI 355??
Old 01-13-2013, 09:50 PM
RamAir95TA's Avatar
There's quite a few people who have gone that fast but keep in mind it's all about the overall setup, not just the heads, that get the car into those times.
Old 01-13-2013, 09:59 PM
Correct im not shooting for tens by any means at this time. Im just doing so plans and not trying to shoot to high. I do wana thank everyone for their opinion's, and info you guys are great!!!
Old 01-13-2013, 10:28 PM
BOLO's Avatar
I will, comes Spring with my LE h/c/i combo
Old 01-14-2013, 06:20 AM
bowtienut's Avatar
Well......not a 355, but with a 350
And with quite a bit more weight than most are carrying.
See sig.
Quick Reply: AI 200cc or LE2 for a 355 lt1
