5th gen Brembos on 4th gen with C5Z06 wheels install pics
Old 01-17-2013, 03:52 PM
nmckeever's Avatar
Default 5th gen Brembos on 4th gen with C5Z06 wheels install pics
Long time lurker so thought id give back. I decided to do the front Brembo swap on my 01 camaro. I had a little trouble finding all the info i needed so figured I'd start a thread with all the parts required and their prices along with pics. 18x9.5 front C5 Z06 wheels do not require wheel spacers
Parts Required/Used
-2010 camaro Brembo front calipers (make sure spindle/caliper bolts are included)- 250$ from Cleveland Pick Apart (http://stores.ebay.com/Cleveland-Pick-A-Part)
- Brake lines from kore3 Industries- 55$
- 14" 2010 Camaro SS rotors from ebay 150$
- Have the inside bore of the rotors machined to 70.7mm by local machine shop - 40$
- Hawk HPS pads- 113$ on ebay
- I had calipers painted red with white Brembo letters- 40$
- 9/16 drill bit- 15$ from Home Depot to drill out holes in the spindle
Really as simple as removing your old calipers and rotors, drilling the spindle to 9/16" holes, replacing the brake lines, putting on new rotors, bolt calipers on (the bolts thread into the calipers)
**NOTE** 18x9.5 C5 Z06 wheels do NOT require wheel spacers
Hope this helps and feel free to PM me with any questions
test fit
Old 01-17-2013, 04:05 PM
Trunion King
bene's Avatar
Nice.
Old 01-17-2013, 04:11 PM
mac62989's Avatar
Looks good!
Old 01-17-2013, 04:24 PM
94Z28-MSTGKLR's Avatar
I wonder if these would clear my TT2's with a spacer.
Old 01-17-2013, 05:08 PM
nmckeever's Avatar
Thanks yall
i bought four 1/4" spacers just in case. Let me know if youre interested in them. could do 10$ each
Old 01-22-2013, 09:06 AM
cookba's Avatar
what is the offset on those wheels?
Old 01-22-2013, 10:36 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
That definitely looks much better then the factory setup!
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 01-22-2013, 11:06 AM
94LT1TA6spd's Avatar
That looks sweet!
Old 01-22-2013, 11:13 AM
Somebody09's Avatar
what's the smallest gap between the rim and caliper?
Old 01-22-2013, 11:14 AM
ramairetransam's Avatar
nice, make it a sticky . very easy setup .
Old 01-22-2013, 11:17 AM
Cajun ELESS-ONE's Avatar
Do want. Thats a slick set up. Seems too easy lol
Old 01-22-2013, 08:10 PM
elis94camaro's Avatar
Wow that looks awesome,just what ive been waiting for. How does it stop?Is this cheaper than all of the other big brake conversions, based on what you have seen?
Old 01-22-2013, 10:48 PM
nmckeever's Avatar
I want to say +56mm offset on the fronts (18x9.5)
night and day difference in stopping. Cannot tell you how much better it is than stock. Wish i would have checked stopping distances before and after to post up here. But I think it adds just as much aesthetically
I mean the rotors I got are not nearly as nice but a similar kit I see listed here for $2900 (http://www.lingenfelter.com/mm5/merc...gory_Code=P016) so its definitely a way cheaper alternative.
Old 01-23-2013, 04:34 AM
ls1fst98's Avatar
Looks great. I want to do this but that means I'd need new wheels and tires.
Old 01-23-2013, 06:52 PM
cookba's Avatar
how much space do you have between the deepest part of the wheel spoke to the caliper? I have the same wheel size and a 56mm offset and was under the impression they would not fit.
Old 01-24-2013, 06:59 AM
LS1HIGHLIFE's Avatar
Looks great dude! Good to see this working out for you. We need to start a list of wheels the brembos will work with and at what offsets.....
Old 01-24-2013, 08:11 AM
5.7 Reasons's Avatar
Good write-up! That's one clean Z28.
Old 01-25-2013, 12:02 PM
ls1fst98's Avatar
Wish there was an alternative for the 17" wheels.
Old 01-25-2013, 12:15 PM
You can run them with 17" wheels, just have to do some grinding....https://ls1tech.com/forums/suspensio...s-17-rims.html
Old 01-25-2013, 01:50 PM
blackpala96's Avatar
What brake line kit did you use? i dont see anything listed.
Anybody have a part number for stock 2010 Camaro SS rotors?
Quick Reply: 5th gen Brembos on 4th gen with C5Z06 wheels install pics
