2000 silverado 2500 LD (sloppy mechanics) 4000 miles later 675whp
Old 01-23-2013, 03:39 PM
Moderator
denmah's Avatar
Default 2000 silverado 2500 LD (sloppy mechanics) 4000 miles later 675whp
bought this thing monday night, i thought it was a pretty good deal, sour from my rusty ranchero, i jumped on this because it has the 6.0 motor, 4l80e, 14bolt rear, 3.73 gears, 411pcm wich supports the easy 3bar speed density update and tuning, already injected, just have to put pumps in the tank, and 80lb injectors and go nuts, i cant wait to get started on it, already have turbos, pumps, meth kit, intercooler, wastegates everything in the mail already.
its a 2000 silverado 2500 LD with 211k miles on it!
Old 01-23-2013, 03:43 PM
ccreddell's Avatar
Next time you go scrounging in the junk yard, try to find a speedo out of a 2500hd or 3500. It has the trans temp gauge and its plug and play.
Old 01-23-2013, 03:44 PM
Moderator
denmah's Avatar
oh nice heads up! thanks!
Old 01-23-2013, 03:53 PM
69 jz28's Avatar
What size turbos are you putting on? I assuming the 6.0 is staying in?
Old 01-23-2013, 03:57 PM
aknovaman's Avatar
Very utility company looking. Btw the alternator bracket is dirty....... Clean for 211k.
You should have some custom vinyl graphics made that say Fuzzy Nuts Electrical Repair Inc. for the doors.
Old 01-23-2013, 04:30 PM
93camaro_zzz's Avatar
Nice find! I have a 2500HD, LQ4, 4L80E, and GM 14 bolt as well. Believe me, I reaaaaaaally am tempted to strapon a simple 76mm and make a good 450rwhp daily driver that can tow absolutely anything.
I am subscribed!
Old 01-23-2013, 05:05 PM
LT1RAY's Avatar
It's too clean to be one of your projects!
Old 01-23-2013, 05:10 PM
Jax326's Avatar
Badass. Plain and simple. Although im a little butthurt, custom cam? After I went and bought the ls9 cam dammit!
Old 01-23-2013, 05:18 PM
831jd's Avatar
Bet this thing will be ready less then a month hotside built turbo tuned and everything lol any takers
Old 01-23-2013, 05:21 PM
superhog88's Avatar
followed the fairmont build was curious why you didnt hook up the iac to the ms1. you enjoy the ls platform have you ever considered a ford mod motor or a hemi
Old 01-23-2013, 05:30 PM
Cronic_Moronic's Avatar
Mod motos aren't as strong as an LSX and hemi's are 'xpensive.
I believe that the only reason denmah is using the lsx platform is the combination of strength and cheep.
Old 01-23-2013, 05:31 PM
Kory 88Iroc Lt1's Avatar
If for the duration. Looks like a clean truck. Looking forward to updates.
Kory
Old 01-23-2013, 06:15 PM
milkey57's Avatar
Sweet another truck!! In for results!
Old 01-23-2013, 06:21 PM
o2camaross's Avatar
Should be lots of fun! I love fast trucks!! You know some of the early 6.0's had iron heads. Does this one?
Old 01-23-2013, 06:44 PM
typhoon1015's Avatar
not bad! ditto, does this have steel heads and the longer crank? or 317s and a short crank/spacer?
drop it 3-4 inches, would look sweet
Old 01-23-2013, 06:58 PM
Moderator
denmah's Avatar
yeah using the motor that came with it for now, why not haha
twin gt35's 61mm
no one is going to bet against your lol
the ms1's i have used had no IAC circut unless i added it and i never cared to
its iron headed, yes
not sure if it is spaced but it is iron headed
we plan to pull the blocks and maybe a leaf if we can, if not 50 dollar drop shackles and then see how it sits, mayyyyyybe cut the front coil a tiny bit then
Moderator
denmah's Avatar
Old 01-23-2013, 07:24 PM
o2camaross's Avatar
Haha cool! Please say you are going to run the iron heads!! I've been really curious as to how they work with boost
Old 01-23-2013, 07:37 PM
1969x11's Avatar
Def.gonna come over to tech to watch this one.
Old 01-23-2013, 07:38 PM
TurboMonte100's Avatar
Cool project, looking forward to more videos.
Quick Reply: 2000 silverado 2500 LD (sloppy mechanics) 4000 miles later 675whp
