Car is sucking something through the I/C pipes
Old 01-24-2013, 09:40 AM
Sweet_SS's Avatar
Default Car is sucking something through the I/C pipes
Like the title states, I got my new radiator and I am in the process of mounting it vertical. Well I started removing my upper I/C piping and noticed something kind of orange in look in the pipe and my new TB. Now this is a new...forged LS3 with FAST TB and the radiator is filled with Prestone coolant...Green. My TC78 is a journal bearing only turbo...no coolant lines. I also pulled the filter and checked the compressor and it looked clean...minimal shaft play as well. What the hell is this stuff? It's not oil....wipes off and doesn't smear. I have lines hooked up to the intake pipe of the turbo for my PCV setup.
Old 01-24-2013, 10:07 AM
F110Mech's Avatar
Rust? That's the only thing that i could think of. maybe from condensation? is your cold side aluminum?
Old 01-24-2013, 10:09 AM
Sweet_SS's Avatar
My cold side is aluminum.
Old 01-24-2013, 10:15 AM
F110Mech's Avatar
Condensation from the iron block circulating from the PCV system? I'm completely shooting from the hip here.
Old 01-24-2013, 10:22 AM
Sweet_SS's Avatar
**** maybe. But how...why would it go through the turbo?
Old 01-24-2013, 10:25 AM
F110Mech's Avatar
sorry, i take that back. I re-read your first post and saw that it's an LS3 block. I'm stumped.
Old 01-24-2013, 10:30 AM
Sweet_SS's Avatar
Your right lol It's an LQ4 block with L92 heads and LS3 forged internals.
Old 01-24-2013, 10:35 AM
F110Mech's Avatar
ahh ok. i would pull a hose off of your PCV system and see if it has the same orange residue.
Old 01-24-2013, 10:44 AM
Sweet_SS's Avatar
Sounds like a good idea. Thanks for the input
Old 01-25-2013, 12:50 AM
SPRAYED 01's Avatar
Its rust .water. Mine does the same if it sits around and forms condensation.
Old 01-25-2013, 08:34 AM
Sweet_SS's Avatar
Cool. I thought it might be from when my LS1 blew. I'm pulling the intercooler and power washing it. Couldn't hurt to clean it up some. Thanks Sprayed01.
Quick Reply: Car is sucking something through the I/C pipes
